compiler question
D. Peter Siddons siddons at bnl.gov
Thu Dec 2 13:42:29 UTC 2004
Hi Ralf,
  I was using 3.2.3 binaries from the OAR site. I ran into a problem
with that when I found that the 'strtok_r' function was not present in
its newlib. So I tried (again from the rtems4.7 OAR site) 3.3.5, with
the result I presented.
Pete.
Ralf Corsepius wrote:
>On Wed, 2004-12-01 at 21:00 -0500, D. Peter Siddons wrote:
>>I just switched to gcc3.3.5 (m68k Coldfire project).
>This compiler is unsupported, you are on your own.
>If you want to try newer GCCs, should you be able to access OAR, try
>their gcc-3.3.*, or try GCC-3.4.4pre from the FSF's gcc-3_4-branch in
>their CVS.
>Ralf
