GPU tech doc
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Dec 10 12:18:38 UTC 2004
Aaron J. Grier wrote:
> On Thu, Dec 09, 2004 at 08:38:47PM +0100, Adriano Verardo wrote:
>>Does anyone know how to get nVIDIA/ATI's GPU technical reference manuals ?
>>I need to write simple SVGA drivers for my applications under RTEMS.
> you might be able to use code from the Xfree86 or X.org projects
> depending on your licensing requirements.
nVidia releases binary only X support and does not provide this
type of documentation.
I think X.org has some ATI drivers.
A simple VGA driver should not need this information as it
should be able to stick to the VESA standard.
