"Can't obtain network semaphore"
Till Straumann strauman at slac.stanford.edu
Wed Dec 15 03:33:31 UTC 2004
Chris Johns wrote:
> Till Straumann wrote:
>> Are you sure none of those deletes the network semaphore?
> If you have RTEMS_FAST_MUTEX defined the semaphore directly accesses the
> score for the mutex. This means _CORE_mutex_Surrender is being called.
Sure - but this doesn't matter. His system panics because
_CORE_mutex_Seize leaves with a return_code=='4' (CORE_MUTEX_WAS_DELETED)
The only way I currently can think of this getting there is
by someone calling rtems_semaphore_delete() on the network
semaphore id.
-- T.
