Booting within running GDB
Wed Dec 15 19:58:33 UTC 2004
Leon Pollak wrote:
> 	Is there any way to execute gdb commands (except Ctrl-C) while application is
> running (by "r" or "c")?
Make the entry point a breakpoint instruction, then in your .gdbinit
script have:
define hook-stop
  if $pc == start
    si
  end
end
where 'start' is your application's entry point. Note, the 'si'
instruction works on the Coldfire how-ever you may need something else
such as 'set $pc = $pc + 2' to skip the breakpoint instruction.
You start gdb with the application's image.
ps: My Right Boot supports the '--debug' command line where it sets the
breakpoint instruction for you. I always have a couple of nops at the
start of my application.
  Chris Johns
