stdc++ (cout) problem with RTEMS on Sparc emulator
Wed Dec 15 23:41:32 UTC 2004
Courtney B. Duncan wrote:
> I think /usr/local/erc32/sparc-rtems/lib/libstdc++.a is the correct one
> and it is the one being linked.  All the permutations of 'revb' 'soft'
> and 'v8' are also present, and I've tried them with the same result
> (doesn't work).  The emulator says that it is V7, Rev C. and has FPU, so
> I don't think I need those other versions.
Ok.
> I have verified that use of the #include file and linking with -lstdc++
> don't cause the problem, it is when something from the library is used
> and part of it is actually pulled in that everything quits.  A single
> line like
> cout << "something";
> or
> vector<int> something;
> will do it.  By disassembling from the start point at 0x02000000, I see
> that pulling in the library radically changes the startup code, causing
> it to jump immediately to memory without valid instructions.
Hmmm, I would check the start up files such as:
  crtbegin.o, crtend.o, crti.o, crtn.o
These are linked in to run the static constructor list via the _init
call (assuming ELF). You can find this call in:
  cpukit/score/src/threadhandler.c
The files listed above need to be correctly multilib'ed to work. I
thought they were always linked in so the start up code should be the same.
Is it possible to set a break point here to see what happens ?
If this is the problem check the list of static constructors is correct.
A failure of this type typically points to a link command file issue.
  Chris Johns
