How to download the PR582 problem fix ?
Jennifer Averett jennifer.averett at oarcorp.com
Thu Dec 23 16:32:33 UTC 2004
Log into the RTEMS GNATS bug database (you can get to it from www.rtems.com on
the left side of the page under bugs).  From there you just enter the PR you
are looking for.  From there you can download the patch.
jennifer
Quoting Alex <kbyte at iol.pt>:
> hi,
> I am having troubles using posix message queues and dr joel pointed me to the
> reason. that troubles come from an existing bug which was already fixed in
> the pr582,
> I am trying to make some research work and I cant change the rtems version,
> so I just want to apply the patch without updating to a newer version, but I
> cant see where to download the patch and how to install the patch
> Can you help me?
> thank you,
> Alex
________________________________________________________________________________
> Veja, em exclusivo no IOL, os vídeos da Quinta das Celebridades!
> http://www.iol.pt/correio/rodape.php?dst=0411152
jennifer
