Separate Development
Manuel Pedro Coutinho
manuelpedrocoutinho at hotmail.com
Wed Dec 29 15:12:58 UTC 2004
Hi
I'm trying to separate the RTEMS development so that a user can have access
to the modified RTEMS version but hasn't a real knowledge of it's internal
details.
Presently, I thought of making 3 different types of users:
a RTEMS official version user
a development user that modifies the official version
a "dumb" user that uses the modified RTEMS version
the official version would have the cross-compiler and the RTEMS sources
the development user would have access to the official version but would
make "small" changes in order to include a new driver, BSP, etc.
the "dumb" user would use the compiled version of the development user.
The development user would have to be the more complex since it has to
modify at least the Makefile.am in some directories and possibly add new
ones (new driver or BSP). The modification of the original source tree is
out of the question because it may generate inconsistencies if the process
fails and stops at half-way, so an alternative way of building is to have
the copy of the directory structure of the RTEMS source containing only the
Makefiles and in the SUB_DIRS parameter place the correct path (for example,
if a directory and all of its sub-directories were of the original package,
then one only has to refer to that directory and not copied its
sub-directories to the development user because the build process would
continue through the original source)
Does anyone have suggestions about this process or have even done a similar
(or different)
approach?
Many thanks
Manuel Coutinho
_________________________________________________________________
MSN Messenger: converse com os seus amigos online.
http://messenger.msn.com.br
