Blackfin CPU support
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Wed Dec 29 15:33:42 UTC 2004
Stefan wrote:
> Hello,
> Does anyone know if RTEMS is been ported to the Analog Devices Blackfin
> processor?
This is the last time I answered this.  Maybe he has made progress.
http://www.rtems.com/ml/rtems-users/2004/august/msg00014.html
That post gave info on the porting documentation and process.
> I am thinking of porting RTEMS to this architecture using the toolchain from
> the ucLinux Blackfin project.
That's probably a good starting point but you will need to make sure
__rtems__ is a predefine and not unix or linux.  Check out the minor
differences most gcc/config/CPU/rtems* files make to a basic *-elf
configuration.
Use their source base and if there is a blackfin-elf target
supported, use that as a basis for blackfin-rtems.
Feel free to ask questions about the porting process and
if you need consulting help, that's what I am here for. :)
> Thanks.
> Stefan.
