Getting reacquainted -- Cygwin/powerpc-rtems Build Error
Mills, John M.
Mills.J at ems-t.com
Thu Dec 30 21:56:53 UTC 2004
Hello -
Returning to RTEMS, I'm trying to build RTEMS-4.6.2 for the powerpc-rtems
targets, under Cygwin in a MsWinXPPro environment. I built a fresh set of
cross-tools based on binutils-2.15, gcc-3.3.5 and newlib-1.11.0 with RTEMS
patches applied and tried a configure/build with "--target=powerpc-rtems
--enable-cxx --enable-tests". Configuration appears to run through, but all
the BSP's builds crash on a 'pthread.h' problem with error reports as
follows:
powerpc-rtems-gcc --pipe -DHAVE_CONFIG_H -isystem
../../../../dmv177/lib/include -D__RTEMS_INSIDE__ -mcpu=603e
-D_OLD_EXCEPTIONS -Dppc603e -O4 -fno-keep-inline-functions -g -Wall -ansi
-fasm -o o-optimize/posixapi.o -c
/usr/src/rtems-4.6.2/c/src/../../cpukit/sapi/src/posixapi.c
In file included from ../../../../dmv177/lib/include/sched.h:21,
from /usr/local/powerpc-rtems/sys-include/pthread.h:15,
from
../../../../dmv177/lib/include/rtems/posix/cond.inl:19,
from ../../../../dmv177/lib/include/rtems/posix/cond.h:158,
from /usr/src/rtems-4.6.2/cpukit/sapi/src/posixapi.c:32:
/usr/local/powerpc-rtems/sys-include/pthread.h:168: error: parse error
before '*' token
[... same error repeated over next 9 lines ...]
/usr/local/powerpc-rtems/sys-include/pthread.h:179: error: parse error
before '*' token
make[4]: *** [o-optimize/posixapi.o] Error 1
There appears to be a circular inclusion path here - does it look familiar
to anyone?
Any suggestions welcome.
Thanks.
John M. Mills
Staff Engineer
EMS Technologies
660 Engineering Drive
Norcross, GA 30092
770.263.9200 ext4882
