error adding new drivers to an exist bsp
sun yongbing
bradon_syb at hotmail.com
Wed Dec 1 07:27:52 UTC 2004
The problem has been solved. My host linux is running on Vmware and when
i modify the files, i download them from Vmware to Winxp and upload them
when finish. There must be something wrong with my change between the
transmission, maybe the style of char or something else, because nothing i
do with my bsp's Makefile.am except add a space into it, the same error
will occur. Now I do all the changes in Vmware, and no errors again.
Thank you any way!
>From: Jay Monkman <jtm-list-rtems at smoothsmoothie.com>
>To: sun yongbing <bradon_syb at hotmail.com>
>CC: rtems-users at rtems.com
>Subject: Re: error adding new drivers to an exist bsp
>Date: Tue, 30 Nov 2004 22:54:03 -0600
>On Wed, Dec 01, 2004 at 09:17:12AM +0800, sun yongbing wrote:
> > then in my bsp dir i run '../../../../../../bootstrap -c', it is
>ok. But
> > when i run '../../../../../../bootstrap',error occurs and error
> > information:
> > ./c/src/lib/libbsp
> > ./c/src/lib/libbsp/m68k/mcf5307buaa
> > aclocal: couldn't open directory `../../../../../../aclocal
> > ': No such file or directory
> > autoheader: error: AC_CONFIG_HEADERS not found in configure.ac
>Are you using the correct versions of autoconf and automake? I think
>RTEMS 4.6 uses autoconf-2.57 and automake-1.7.2
_________________________________________________________________
免费下载 MSN Explorer: http://explorer.msn.com/lccn
