socket question
Till Straumann
strauman at slac.stanford.edu
Wed Dec 1 18:38:10 UTC 2004
Maybe the SO_RCVWAKEUP / SO_SNDWAKEUP callbacks are
useful (check connection status) ?
HTH
-T.
Steve Holle wrote:
> I'm using sockets in a telnet type application. My server starts two
> threads, a read and write, on an "accept." Up to four pairs of threads,
> sessions, are allowed. The read thread blocks on a recv/timeout routine
> and the write blocks on an rtems queue, with a timeout of one second.
> Thanks for your help on that one everyone who responded.
> The problem I'm having is closing the write thread when the connection
> is closed from the client. The read thread closes fine but I'm having
> trouble determining how to detect a closed connection in the write
> thread. I would prefer that the thread kill itself when the connections
> closes because there can be up to four of them and I'm lazy and don't
> want to figure out which one needs killing inside the read thread. That
> seems like unnecessary coupling between the read and write threads also.
> Is there a way I can determine, on the one second interval provided by
> the rtems queue timeout, if a connection is closed?
> Let me know if you want to see the code.
> Steve Holle
> Link Communications, Inc.
> 1035 Cerise Rd.
> Billings, MT 59101
> sholle at link-comm.com
