Capture Engine
Steve Holle
sholle at link-comm.com
Thu Dec 9 14:51:45 UTC 2004
At 02:38 PM 12/8/2004, Chris Johns wrote:
>Steve Holle wrote:
>>I'm trying to use the Capture Engine and the rtems monitor and am having
>>some trouble. I've reviewed the document on the wiki and added the lines
>>recommended but am unable to get a prompt. As a matter of fact, when I
>>include the rtems_monitor_init and rtems_capture_cli_init I loose serial
>>communications.
>The RTEMS monitor will block on stdin. The capture engine's CLI registers
>commands with the RTEMS monitor. The CLI uses stdin and stdout.
>If you have 2 tasks blocking on the stdin the IO will become confused.
I think I have a workaround for this.
>>I am unfamiliar with the rtems monitor.
>>Can it be redirected to a telnet port?
>I am not sure the RTEMS monitor can be redirected. I do not know the RTEMS
>telnet server that well to be sure.
>>Where is it documented?
>Not sure about the RTEMS monitor, but the wiki is the best place for
>the Capture Engine.
>>How is it configured?
>The Capture Engine is a generic layer with an API defined in capture.h.
>The CLI is an interface to the Capture Engine using this API.
>The design allows you to embedded capture engine commands in your
>application so you can create a user interface that suits you.
>The CLI takes care of the initialisation, how-ever sometime you wish to
>have the capture engine run from the start. This is an example is C++ that
>initialise the CLI, opens the engine, turns it on, sets a global watch
>(trace all events), and then sets a trigger from my init task called 'main':
>void
>setup_capture_engine ()
> rtems_status_code sc;
> rtems_capture_cli_init (0);
> sc = rtems_capture_open (500, 0);
> if (sc != RTEMS_SUCCESSFUL)
> std::cout << "capture error: open failed: "
> << rtems_status_text (sc) << std::endl;
> return;
> sc = rtems_capture_control (1);
> std::cout << "capture error: enable failed: "
> return;
> sc = rtems_capture_watch_global (1);
> std::cout << "capture error: enable global watch failed: "
> return;
> sc = rtems_capture_set_trigger (rtems_build_name ('m', 'a', 'i', 'n'),
> 0, 0, 0, rtems_capture_to_any);
> std::cout << "capture error: set trigger failed: "
> return;
> std::cout << "capture engine opened and enabled." << std::endl;
>To dump the trace I use the CLI, you could add code to perform this task
>if you wish.
>>The document on the wiki does a good job of documenting the commands but
>>a demo session would be very helpful.
>Are you after a demo of the CLI commands or a demo of using the Capture
>Engine API to embedded it in your application ?
I think what you've given me above is a good example of the API. If you
could give me a demo of the CLI I'd appreciate that also.
Thanks.
> Chris Johns
Steve Holle
Link Communications, Inc.
1035 Cerise Rd.
Billings, MT 59101
