My own driver
Adam Piotrowski komam at interia.pl
Mon Dec 13 16:14:57 UTC 2004
> You seem to be on the right track but you didn't mention what type of
> device you are writing a driver for.  At least serial ports,
> disks/non-volatile storage for filesystems, real-time clocks, and
> network interface controllers have frameworks to adhere to in
> order to plug into standard subsystems.
> What tpe of device is it?  Then we can point you to a good example
> or maybe a template for the device driver.
> For example, a clock tick or serial port driver can often just be a
> few lines of BSP specific glue code.
First, I try understood this system and driver model. I planed write simple
memory driver (driver that will remember what I write, and send back that
information when I read), but the final project will be driver for Flash
memory (non-volatile storage for filesystems). In documentation I found
information that somewhere in rtems is driver for non-volatine memory but I
couldn't have found it.
Adam Piotrowski
Startuj z INTERIA.PL!!! >>> http://link.interia.pl/f1837
