Thread question
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Mon Dec 13 16:23:24 UTC 2004
Steve Holle wrote:
> At 05:05 PM 12/10/2004, Angelo Fraietta wrote:
>> Steve Holle wrote:
>>> If I disable task 1A, 1B keeps running even with the streaming audio
>>> running.
>>> I assumes that since 1A and 1B where set up to timeslice that
>>> whatever time was left 1A and 1B would get serviced. That is
>>> obviously a false assumption.
>> I am pretty sure that if a higher priority thread takes control at any
>> stage, the thread that was switched out will get switched back in;
>> however, it's timeslices will start again at zero. It is possible in
>> that case for one thread to get starved because the thread of equal
>> priority keeps getting switched back with it's timeslice count set
>> back to the start
> I'm not sure I understand this. Why should it's timeslice restart?
> That seems counter-intuitive. That would explain the symptoms we are
> seeing but I'm not sure I understand the purpose and how to use
> timeslicing if this is the case.
THe way timeslicing is defined in the Classic API, it is just a limit on
how long a thread can run without giving up the processor. If it ever
gives up the CPU, it will have its timeslice reset when it runs again.
POSIX has a slightly different definition of timeslice quantum
handling. It is not reset until it is actually exhausted.
A quick hack to try the POSIX version is to change the taskcreate.c
call to _Thread_initialize to use EXHAUST_TIMESLICE not RESET_TIMESLICE.
There has been a wishlist for a while to be able to specify which
algorithm to use. Maybe you have finally got a case where it matters. :)
--joel
