"Can't obtain network semaphore"
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Wed Dec 15 12:14:23 UTC 2004
Chris Johns wrote:
> Till Straumann wrote:
>> Are you sure none of those deletes the network semaphore?
> If you have RTEMS_FAST_MUTEX defined the semaphore directly accesses the
> score for the mutex. This means _CORE_mutex_Surrender is being called.
I think the semaphore code has been optimized to the point where this
code should be removed. There is little point to it now.
joel at OARcorp.com On-Line Applications Research
