volatile in struct
Sergei Organov osv at topconrd.ru
Mon Feb 16 18:44:12 UTC 2004
Juergen Zeller <juergen.zeller at argovision.de> writes:
> Hello all,
> I'm confused, I need help from the specialists!
1. You should protect your shared data with *the same* primitive in all the
   threads. Either use rtems_interrupt_x in both threads or use
   rtems_semaphore_x in both threads.
2. Using volatile is almost never a good idea. If you use RTOS primitives for
   mutual exclusion correctly, you don't need volatile for your protected
   data.
Sergei.
