some newbie questions
Ed Sutter els at emailbox.hdtv.lucent.com
Mon Feb 16 19:33:35 UTC 2004
Seb,
I don't know too much about the ip450mon and the "lo" command; however,
if it just dies, then it sounds like the srecord may be pointing to
space that is used by the monitor itself, and the download is corrupting
RAM that is owned/used by the monitor in runtime.
Is it possible that you have a conflict between the monitor and app
memory maps?
Ed
sebastian ssmoller wrote:
> hi,
> the hints u gave me so far helped me a lot. the last two days i read
> some more docs about rtems and managed to build the hello world sample
> for pc386 and boot it via grub :)
> then i build the hello world for gen68360 and tried to start it on an ip
> 460 developer board (68040 + 68360). unfortunately i wasnt able to load
> the file (s-record file) over the serial line :(
> usually i would connect to the board (ip460mon) via terminal prog, use
> the "lo" command to download the s19 file and run "ca" to start the
> prog. when i try "lo" with the hello world app nothing happens. i mean:
> i send the file and when finished the board usually answers "what ?" but
> it doesnt. i waited some minutes (10 min for 260k over 34800).
> the only thing i found out so far is that usually the srec file has s1
> records (generated with introl code compiler) but the rtems objcopy
> output has s2 records. i dont know whether it does matter (?)
> i would expect that even if the output format is not correct the
> download should just finish and possibly the "ca" would fail (?)
> does anyone have any ideas ?
> thx again
> regards,
> seb
