some newbie questions
sebastian ssmoller sebastian.ssmoller at gmx.net
Wed Feb 18 17:59:48 UTC 2004
hi,
using an "independent" function is of cause a good idea :)
calling this funct does NOT cause the board to hang - so this is one step
into the right direction :)
i wasnt able yet to get the value of the variable - i have to read some
docs about the monitor first.
but what i did is, i only include a printf (which causes to inlcude and use
lots of other stuff of course). calling the funct again caused a bus error.
next pc points into the fstat function ...
this let me believe that my linkcmds file is not correct. so possibly u
could have a look at it ?
====== linkcmds from intro (which works) =========
// This linker command file was created by Introl-CODE.
// Library modules used by this program
// Program memory groups
group ROM rom itemalign 2 origin 0x0700 maxsize 0x10000-0x0700;
    section .vectors data;
    section .start0 text;
    section .start1 text;
    section .start2 text;
    section .start3 text;
    section .start4 text;
    section .start5 text;
    section .start6 text;
    section .start7 text;
    section .start8 text;
    section .start9 text;
    section .startX text;
    section .startZ text;
    section ROM.const data = .const .strings;
    section ROM.text text = .text;
    section .init;
group ROM;
set __ROMstart = 0x0700;
set __ROMend = 0x10000;
set __ROMsize = 0x10000-0x0700;
group RAM ram bss itemalign 2 origin 0x10000 maxsize 0x50000-0x10000;
    section .bss comms;
    section .data data copiedfrom .init;
    section .retm comm;
    section .heap expand minsize 0;
    section .stack minsize 0;
    section RAM.ubss = .ubss;
group RAM;
set __RAMstart = 0x10000;
set __RAMend = 0x50000;
set __RAMsize = 0x50000-0x10000;
group IO io bss origin 0xFFF000 maxsize 0x1000000-0xFFF000;
    section .chip;
group IO;
set __IOstart = 0xFFF000;
set __IOend = 0x1000000;
set __IOsize = 0x1000000-0xFFF000;
// Link time variable definitions
set __ramstart = startof(.bss);
set __ramend = endof(.bss);
set __heapstart = startof(.heap);
set __heapend = endof(.heap);
set __stackstart = startof(.stack);
set __stackend = endof(.stack);
set __initstart = startof(.init);
set __initend = endof(.init);
set __datastart = startof(.data);
set __dataend = endof(.data);
set __fastend = endof(.start1);
set __chipstart = startof(.chip);
readline;	// Read files from the command line
end;
============ linkcmds intro end ==================
============ linkcmds from rtems (with memory values changed) ========
 * This file contains GNU linker directives for a generic MC68360 board.
 * Variations in memory size and allocation can be made by
 * overriding some values with linker command-line arguments.
 * Saskatchewan Accelerator Laboratory
 * University of Saskatchewan
 * Saskatoon, Saskatchewan, CANADA
 * eric at skatter.usask.ca
 *  linkcmds,v 1.20 2003/01/20 20:19:44 joel Exp
OUTPUT_FORMAT("srec");
 * Declare some sizes.
 * A heap size of 0 means `use all available memory for the heap'.
_RamBase = DEFINED(_RamBase) ? _RamBase : 0x10000;
_RamSize = DEFINED(_RamSize) ? _RamSize : 0x50000-0x10000;
_HeapSize = DEFINED(_HeapSize) ? _HeapSize : 0x0;
_StackSize = DEFINED(_StackSize) ? _StackSize : 0x1000;
 * Declare on-board memory.
MEMORY {
          rom : ORIGIN = 0x0700,  LENGTH = 0x10000 - 0x0700
          ram : ORIGIN = 0x10000, LENGTH = 0x50000 - 0x10000
        dpram : ORIGIN = 0xFFC00001, LENGTH = 0xFFC02000 - 0xFFC00000
 * Load objects
SECTIONS {
         * Boot PROM
        rom : {
                _RomBase = .;
        } >rom
         * Dynamic RAM
        ram : {
                _RamBase = .;
        } >ram
         * Text, data and bss segments
        .text : {
                *(.text)
		         * C++ constructors/destructors
        		*(.gnu.linkonce.t.*)
        		 * Initialization and finalization code.
        		PROVIDE (_init = .);
        		*crti.o(.init)
        		*(.init)
        		*crtn.o(.init)
        		PROVIDE (_fini = .);
        		*crti.o(.fini)
        		*(.fini)
        		*crtn.o(.fini)
        		 * Special FreeBSD sysctl sections.
        		. = ALIGN (16);
        		__start_set_sysctl_set = .;
        		*(set_sysctl_*);
        		__stop_set_sysctl_set = ABSOLUTE(.);
        		*(set_domain_*);
        		*(set_pseudo_*);
        		. = ALIGN (16);
        		*crtbegin.o(.ctors)
        		*(.ctors)
        		*crtend.o(.ctors)
        		*crtbegin.o(.dtors)
        		*(.dtors)
        		*crtend.o(.dtors)
        		 * Exception frame info
        		. = ALIGN (16);
        		*(.eh_frame)
        		 * Read-only data
        		. = ALIGN (16);
        		_rodata_start = . ;
        		*(.rodata*)
        		*(.gnu.linkonce.r*)
                 . = ALIGN (16);
                PROVIDE (etext = .);
        } >ram
        .data : {
                _copy_start = .;
                *(.data)
        		*(.gnu.linkonce.d*)
		        *(.gcc_except_table)
		        *(.jcr)
                . = ALIGN (16);
                PROVIDE (edata = .);
                _copy_end = .;
        } >ram
        .bss : {
                M68Kvec = .;
                . += (256 * 4);
                _clear_start = .;
                *(.bss)
                *(COMMON)
                . = ALIGN (16);
                PROVIDE (end = .);
                . += _StackSize;
                . = ALIGN (16);
                _stack_init = .;
                _clear_end = .;
                _WorkspaceBase = .;
                variable = .;
        } >ram
         * On-chip memory/peripherals
        dpram : {
                m360 = .;
                . += (8 * 1024);
        } >dpram
  /* Stabs debugging sections.  */
  .stab 0 : { *(.stab) }
  .stabstr 0 : { *(.stabstr) }
  .stab.excl 0 : { *(.stab.excl) }
  .stab.exclstr 0 : { *(.stab.exclstr) }
  .stab.index 0 : { *(.stab.index) }
  .stab.indexstr 0 : { *(.stab.indexstr) }
  .comment 0 : { *(.comment) }
  /* DWARF debug sections.
     Symbols in the DWARF debugging sections are relative to the beginning
     of the section so we begin them at 0.  */
  /* DWARF 1 */
  .debug          0 : { *(.debug) }
  .line           0 : { *(.line) }
  /* GNU DWARF 1 extensions */
  .debug_srcinfo  0 : { *(.debug_srcinfo) }
  .debug_sfnames  0 : { *(.debug_sfnames) }
  /* DWARF 1.1 and DWARF 2 */
  .debug_aranges  0 : { *(.debug_aranges) }
  .debug_pubnames 0 : { *(.debug_pubnames) }
  /* DWARF 2 */
  .debug_info     0 : { *(.debug_info) }
  .debug_abbrev   0 : { *(.debug_abbrev) }
  .debug_line     0 : { *(.debug_line) }
  .debug_frame    0 : { *(.debug_frame) }
  .debug_str      0 : { *(.debug_str) }
  .debug_loc      0 : { *(.debug_loc) }
  .debug_macinfo  0 : { *(.debug_macinfo) }
  /* SGI/MIPS DWARF 2 extensions */
  .debug_weaknames 0 : { *(.debug_weaknames) }
  .debug_funcnames 0 : { *(.debug_funcnames) }
  .debug_typenames 0 : { *(.debug_typenames) }
  .debug_varnames  0 : { *(.debug_varnames) }
  /* These must appear regardless of  .  */
============ linkcmds rtems end ==================
i checked the "ca" (call) syntax again and i guess it is correct, cause it
works with introl code and when calling the unique_function
many thx again
regards,
seb
On Wed, 18 Feb 2004 12:14:30 -0500
Ed Sutter <els at emailbox.hdtv.lucent.com> wrote:
> Seb,
> Try starting with something simpler.
> Here's a few suggestions...
> In your application add a function and a variable..
> long unique_variable;
> long
> unique_function(void)
> 	return(++unique_variable);
> Then load your application and instead of calling the entrypoint,
> parse your symbol table and call this function's address.  If this
> hangs, you have a more fundamental problem, if it doesn't hang
> the do some more investigation...
> If the "call" command that you have shows the return value of the
> function you called, then you should notice it incrementing.
> If the "call" command doesn't support that, then call the function
> and then display the variable using some other monitor command.
> Another thing to try would be to disassemble the the address of
> the application entrypoint and see if it makes sense.
> The point here is to test some of the stuff outside of RTEMS.
> Make sure your "call" command is working the way you think, etc...
> For example, maybe "call" gets confused if your address is not prefixed
> with "0x".  Or, maybe it gets confused if yoru address IS prefixed
> with "0x".
> Get the idea? These things will just give you a confidence level
> (maybe good maybe not so good) in what you're doing.
> Ed
