some newbie questions
Wed Feb 18 18:53:46 UTC 2004
Ed Sutter wrote:
> Seb,
> You can't call something with printf() in it at this level.
> Think about it...
> The guts of printf() requires console IO to be working.
> Console IO is likely handled by the serial port device
> driver in RTEMS.  Since we're side-stepping the whole
> RTOS startup here,  printf() will certainly not work.
But printk probably will if you have a stack and the
BSP output char hook filled it.
--joel
> Ed
> sebastian ssmoller wrote:
>>hi,
>>using an "independent" function is of cause a good idea :)
>>calling this funct does NOT cause the board to hang - so this is one step
>>into the right direction :)
>>i wasnt able yet to get the value of the variable - i have to read some
>>docs about the monitor first.
>>but what i did is, i only include a printf (which causes to inlcude and use
>>lots of other stuff of course). calling the funct again caused a bus error.
>>next pc points into the fstat function ...
>>this let me believe that my linkcmds file is not correct. so possibly u
>>could have a look at it ?
>>====== linkcmds from intro (which works) =========
>>// This linker command file was created by Introl-CODE.
>>// Library modules used by this program
>>// Program memory groups
>>group ROM rom itemalign 2 origin 0x0700 maxsize 0x10000-0x0700;
>>    section .vectors data;
>>    section .start0 text;
>>    section .start1 text;
>>    section .start2 text;
>>    section .start3 text;
>>    section .start4 text;
>>    section .start5 text;
>>    section .start6 text;
>>    section .start7 text;
>>    section .start8 text;
>>    section .start9 text;
>>    section .startX text;
>>    section .startZ text;
>>    section ROM.const data = .const .strings;
>>    section ROM.text text = .text;
>>    section .init;
>>group ROM;
>>set __ROMstart = 0x0700;
>>set __ROMend = 0x10000;
>>set __ROMsize = 0x10000-0x0700;
>>group RAM ram bss itemalign 2 origin 0x10000 maxsize 0x50000-0x10000;
>>    section .bss comms;
>>    section .data data copiedfrom .init;
>>    section .retm comm;
>>    section .heap expand minsize 0;
>>    section .stack minsize 0;
>>    section RAM.ubss = .ubss;
>>group RAM;
>>set __RAMstart = 0x10000;
>>set __RAMend = 0x50000;
>>set __RAMsize = 0x50000-0x10000;
>>group IO io bss origin 0xFFF000 maxsize 0x1000000-0xFFF000;
>>    section .chip;
>>group IO;
>>set __IOstart = 0xFFF000;
>>set __IOend = 0x1000000;
>>set __IOsize = 0x1000000-0xFFF000;
>>// Link time variable definitions
>>set __ramstart = startof(.bss);
>>set __ramend = endof(.bss);
>>set __heapstart = startof(.heap);
>>set __heapend = endof(.heap);
>>set __stackstart = startof(.stack);
>>set __stackend = endof(.stack);
>>set __initstart = startof(.init);
>>set __initend = endof(.init);
>>set __datastart = startof(.data);
>>set __dataend = endof(.data);
>>set __fastend = endof(.start1);
>>set __chipstart = startof(.chip);
>>readline;       // Read files from the command line
>>end;
>>============ linkcmds intro end ==================
>>============ linkcmds from rtems (with memory values changed) ========
>> * This file contains GNU linker directives for a generic MC68360 board.
>> * Variations in memory size and allocation can be made by
>> * overriding some values with linker command-line arguments.
>> * Saskatchewan Accelerator Laboratory
>> * University of Saskatchewan
>> * Saskatoon, Saskatchewan, CANADA
>> * eric at skatter.usask.ca
>> *  linkcmds,v 1.20 2003/01/20 20:19:44 joel Exp
>>OUTPUT_FORMAT("srec");
>> * Declare some sizes.
>> * A heap size of 0 means `use all available memory for the heap'.
>>_RamBase = DEFINED(_RamBase) ? _RamBase : 0x10000;
>>_RamSize = DEFINED(_RamSize) ? _RamSize : 0x50000-0x10000;
>>_HeapSize = DEFINED(_HeapSize) ? _HeapSize : 0x0;
>>_StackSize = DEFINED(_StackSize) ? _StackSize : 0x1000;
>> * Declare on-board memory.
>>MEMORY {
>>          rom : ORIGIN = 0x0700,  LENGTH = 0x10000 - 0x0700
>>          ram : ORIGIN = 0x10000, LENGTH = 0x50000 - 0x10000
>>        dpram : ORIGIN = 0xFFC00001, LENGTH = 0xFFC02000 - 0xFFC00000
>> * Load objects
>>SECTIONS {
>>         * Boot PROM
>>        rom : {
>>                _RomBase = .;
>>        } >rom
>>         * Dynamic RAM
>>        ram : {
>>                _RamBase = .;
>>        } >ram
>>         * Text, data and bss segments
>>        .text : {
>>                *(.text)
>>                         * C++ constructors/destructors
>>                        *(.gnu.linkonce.t.*)
>>                         * Initialization and finalization code.
>>                        PROVIDE (_init = .);
>>                        *crti.o(.init)
>>                        *(.init)
>>                        *crtn.o(.init)
>>                        PROVIDE (_fini = .);
>>                        *crti.o(.fini)
>>                        *(.fini)
>>                        *crtn.o(.fini)
>>                         * Special FreeBSD sysctl sections.
>>                        . = ALIGN (16);
>>                        __start_set_sysctl_set = .;
>>                        *(set_sysctl_*);
>>                        __stop_set_sysctl_set = ABSOLUTE(.);
>>                        *(set_domain_*);
>>                        *(set_pseudo_*);
>>                        . = ALIGN (16);
>>                        *crtbegin.o(.ctors)
>>                        *(.ctors)
>>                        *crtend.o(.ctors)
>>                        *crtbegin.o(.dtors)
>>                        *(.dtors)
>>                        *crtend.o(.dtors)
>>                         * Exception frame info
>>                        . = ALIGN (16);
>>                        *(.eh_frame)
>>                         * Read-only data
>>                        . = ALIGN (16);
>>                        _rodata_start = . ;
>>                        *(.rodata*)
>>                        *(.gnu.linkonce.r*)
>>                 . = ALIGN (16);
>>                PROVIDE (etext = .);
>>        } >ram
>>        .data : {
>>                _copy_start = .;
>>                *(.data)
>>                        *(.gnu.linkonce.d*)
>>                        *(.gcc_except_table)
>>                        *(.jcr)
>>                . = ALIGN (16);
>>                PROVIDE (edata = .);
>>                _copy_end = .;
>>        } >ram
>>        .bss : {
>>                M68Kvec = .;
>>                . += (256 * 4);
>>                _clear_start = .;
>>                *(.bss)
>>                *(COMMON)
>>                . = ALIGN (16);
>>                PROVIDE (end = .);
>>                . += _StackSize;
>>                . = ALIGN (16);
>>                _stack_init = .;
>>                _clear_end = .;
>>                _WorkspaceBase = .;
>>                variable = .;
>>        } >ram
>>         * On-chip memory/peripherals
>>        dpram : {
>>                m360 = .;
>>                . += (8 * 1024);
>>        } >dpram
>>  /* Stabs debugging sections.  */
>>  .stab 0 : { *(.stab) }
>>  .stabstr 0 : { *(.stabstr) }
>>  .stab.excl 0 : { *(.stab.excl) }
>>  .stab.exclstr 0 : { *(.stab.exclstr) }
>>  .stab.index 0 : { *(.stab.index) }
>>  .stab.indexstr 0 : { *(.stab.indexstr) }
>>  .comment 0 : { *(.comment) }
>>  /* DWARF debug sections.
>>     Symbols in the DWARF debugging sections are relative to the beginning
>>     of the section so we begin them at 0.  */
>>  /* DWARF 1 */
>>  .debug          0 : { *(.debug) }
>>  .line           0 : { *(.line) }
>>  /* GNU DWARF 1 extensions */
>>  .debug_srcinfo  0 : { *(.debug_srcinfo) }
>>  .debug_sfnames  0 : { *(.debug_sfnames) }
>>  /* DWARF 1.1 and DWARF 2 */
>>  .debug_aranges  0 : { *(.debug_aranges) }
>>  .debug_pubnames 0 : { *(.debug_pubnames) }
>>  /* DWARF 2 */
>>  .debug_info     0 : { *(.debug_info) }
>>  .debug_abbrev   0 : { *(.debug_abbrev) }
>>  .debug_line     0 : { *(.debug_line) }
>>  .debug_frame    0 : { *(.debug_frame) }
>>  .debug_str      0 : { *(.debug_str) }
>>  .debug_loc      0 : { *(.debug_loc) }
>>  .debug_macinfo  0 : { *(.debug_macinfo) }
>>  /* SGI/MIPS DWARF 2 extensions */
>>  .debug_weaknames 0 : { *(.debug_weaknames) }
>>  .debug_funcnames 0 : { *(.debug_funcnames) }
>>  .debug_typenames 0 : { *(.debug_typenames) }
>>  .debug_varnames  0 : { *(.debug_varnames) }
>>  /* These must appear regardless of  .  */
>>============ linkcmds rtems end ==================
>>i checked the "ca" (call) syntax again and i guess it is correct, cause it
>>works with introl code and when calling the unique_function
>>many thx again
>>regards,
>>seb
>>On Wed, 18 Feb 2004 12:14:30 -0500
>>Ed Sutter <els at emailbox.hdtv.lucent.com> wrote:
>>>Seb,
>>>Try starting with something simpler.
>>>Here's a few suggestions...
>>>In your application add a function and a variable..
>>>long unique_variable;
>>>long
>>>unique_function(void)
>>>      return(++unique_variable);
>>>Then load your application and instead of calling the entrypoint,
>>>parse your symbol table and call this function's address.  If this
>>>hangs, you have a more fundamental problem, if it doesn't hang
>>>the do some more investigation...
>>>If the "call" command that you have shows the return value of the
>>>function you called, then you should notice it incrementing.
>>>If the "call" command doesn't support that, then call the function
>>>and then display the variable using some other monitor command.
>>>Another thing to try would be to disassemble the the address of
>>>the application entrypoint and see if it makes sense.
>>>The point here is to test some of the stuff outside of RTEMS.
>>>Make sure your "call" command is working the way you think, etc...
>>>For example, maybe "call" gets confused if your address is not prefixed
>>>with "0x".  Or, maybe it gets confused if yoru address IS prefixed
>>>with "0x".
>>>Get the idea? These things will just give you a confidence level
>>>(maybe good maybe not so good) in what you're doing.
>>>Ed
