some newbie questions
Ed Sutter els at emailbox.hdtv.lucent.com
Thu Feb 19 20:44:26 UTC 2004
Anybody out there a 68360 whiz?
I've never used it, just did a quick scan of the UM.
Just thinking about some general 68k stuff...
Are you in supervisor mode when you attempt to write this?
Is it possible that your monitor is running at user level when
you attempt to run this code? (keep in mind, that I'm not even
sure you NEED to be in supv mode, just making some suggestions).
Ed
sebastian ssmoller wrote:
> section 6.8.1 in 68360 users manual says
> "second, the MBAR, newly located at address $0003ff04, can only be
> enabled for access after a keyed write operation is performed" and later
> on there is described that one has to write FFFFFFFE to MBARE before
> MBAR could be set. even if that section talks about multiple QUICC
> slaves : could this be the problem ?
> regards,
> seb
> On Thu, 19 Feb 2004 14:35:53 -0500
> Ed Sutter <els at emailbox.hdtv.lucent.com> wrote:
> > Nevermind!!!
> > I just scanned futher through the manual and it appears that the first
> > instance of the MBAR address has a typo.  All other references in the
> > manual use 0x3ff04, not 0x33ff04.
> > Sorry about that!
> > Ed
> > > hi,
> > > finally i used the approach: incrementing a variable an see where it
> > > stops.
> > > > Seb,
> > > > Just reset the board (don't powercycle).  In most cases this
> > > > doesn't
> > > > corrupt memory.  Usually, assuming you have a reset or NMI type
> > > > of button, you can get yourself back to the monitor, then in RAM
> > > > space you essentially have the equivalent of a core dump.
> > > i did so and it worked perfectly well.
> > > i started debugging at c/src/lib/libbsp/m68k/gen68360/start/start.S
> > > where the start symbol which i call is defined. i found out that the
> > > board hangs immediately at step 4 where mbar is set.
> > >    * Step 4: Write the MBAR
> > >     movec   dfc,d1          | Save destination register
> > >     moveq   #7,d0           | CPU-space funcction code
> > >     movec   d0,dfc          | Set destination function code register
> > >     movel   #m360+0x101,d0  | MBAR value (mask CPU space accesses)
> > > /* with the execution of the next line the board will hang */
> > >     movesl  d0,0x3FF04     | Set MBAR
> > >     movec   d1,dfc          | Restore destination register
> > > the original addr of the MBAR was 0x3ff00 as described in the 68360
> > > manual (which failed). i read again the doc of my board and it says
> > > that
> > > MBAR is at 0x3ff04. so i changed the value but nothing happens - the
> > > board still hangs :(
> > > thx
> > > regards,
> > > seb
> > > Microsoft: Where do you want to go today?
> > > Linux: Where do you want to go tomorrow?
> > > FreeBSD: Are you guys coming or what?
> > > OpenBSD: Hey guys you left some holes out there!
