Posix Threads
Ralf Corsepius corsepiu at faw.uni-ulm.de
Fri Feb 20 14:02:32 UTC 2004
On Fri, 2004-02-20 at 12:34, sashti srinivasan wrote:
> Hello All,
>      One more doubt.  Instead of using the traditional
> makefile distributed with example applications, I have
> made my own (from whatever appeared on the console
> while running make on the distributed makefile).
IMO, a very good idea! Just treat using RTEMS like you would treat the
OS in other application development environments.
[It's not a secret that I dislike the RTEMS example Makefiles and would
like to see them abandoned ASAP.]
>   This
> also works fine.  During link time, if we link with
> some .rel files, some of the directives do not work.
> Please explain me what are these .rel files.
relocatible object files.
They "glue" together several *.o's into another object files, which are
treated as separate entity when linking.
Compilation-wise, they are similar to separate programs, which resolve
their link-dependencies against the OS.
>   I am
> sorry if it is a trivial doubt.  In this case, please
> give me pointers about this.
Check ld's and gcc's documentation for "-r".
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung (FAW)
Helmholtzstr. 16, 89081 Ulm, Germany     Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de           FAX: +49/731/501-999
http://www.faw.uni-ulm.de
