"new" operator not allocating enough memory?
Mark Mussetter
mark at link-comm.com
Fri Feb 20 21:31:54 UTC 2004
Hello Everyone,
I seem to be having trouble with operator "new" not allocating enough
memory for FLTK objects. Displaying the sizeof the objects in the debugger
returns the correct size, but printing the sizeof the objects from within
the program gives the wrong result (it matches the amount of space that
"new" allocates). We are using the V4.6pre5 m68k-rtems-gcc compiler. Is
there something I could be doing wrong that would cause the compiler to
calculate the sizeof the object incorrectly?
I am trying to run the HelloWorld.cc example program from FLTK1.1.4 on our
target. Our target is a Motorola 5272 running RTEMS and Microwindows-0.90
(both of which work fine without FLTK). The program creates two
objects: a Fl_Window and a Fl_Box. The problem seems to be that the "new"
operator isn't allocating enough memory for the Fl_Box object, so when it
gets initialized, it overwrites part of the Fl_Window data (the vptr is one
victim, which obviously causes problems later). If I comment out the
Fl_Box code and just display a window, everything works (though some other
memory might be getting overwritten that doesn't have an obvious effect).
I loaded the app in DDD and stepped into the "new" operation and saw that
40 bytes were allocated for the box, but when I checked
"sizeof(*box)" from the (gdb) prompt, I get 66 bytes as a result (66 is
the correct size, based on manually adding up the size of the data in an
Fl_Box). Just to add another sanity check, I added printf statements to
the code to see how "new" was allocating storage for the two objects and
got the following results, which seem to agree with the amount of space
"new" is allocating:
Sizeof(Fl_Window) = (0x5C) 92 bytes (this should be 126 per the
debugger and a manual count)
Sizeof(*window) = (0x5C) 92 bytes
Sizeof(Fl_Box) = (0x28) 40 bytes (this should be 66 per the
Sizeof(*box) = (0x28) 40 bytes
Address of *window = (0x57D3B8) 5755832
Address of *box = (0x57D384) 5755780
The code is small, so I'm attaching it below.
Any help would be greatly appreciated!
Mark Mussetter
Link Communications, Inc.
email: <mailto:mark at link-comm.com>mark at link-comm.com
phone: (406) 245-5002 ext 105
Fax: (406) 245-4889
#include <FL/Fl.H>
#include <FL/Fl_Window.H>
#include <FL/Fl_Box.H>
extern "C" void startupLCD(void);
extern "C" void touchScreenInit(void);
extern "C" int rtems_main(int argc, char **argv);
int rtems_main(int argc, char **argv) {
Fl_Window *window = new Fl_Window(200,180);
Fl_Box *box = new Fl_Box(20,40,170,100,"Hello, World!");
printf( "Sizeof(Fl_Window) = (0x%X) %d bytes\n",
sizeof(Fl_Window), sizeof(Fl_Window) );
printf( "Sizeof(*window) = (0x%X) %d bytes\n", sizeof(*window),
sizeof(*window) );
printf( "Sizeof(Fl_Box) = (0x%X) %d bytes\n", sizeof(Fl_Box),
sizeof(Fl_Box) );
printf( "Sizeof(*box) = (0x%X) %d bytes\n", sizeof(*box),
sizeof(*box) );
printf( "Address of *window = (0x%X) %d\n", window,window );
printf( "Address of *box = (0x%X) %d\n", box,box );
startupLCD();
touchScreenInit();
box->box(FL_UP_BOX);
box->labelsize(36);
box->labelfont(FL_BOLD+FL_ITALIC);
//box->labeltype(FL_SHADOW_LABEL);
window->end();
window->show(argc, argv);
return Fl::run();
