"new" operator not allocating enough memory?
Mark Mussetter mark at link-comm.com
Fri Feb 20 22:51:11 UTC 2004
I sent the class definitions directly to Angelo...If anyone else wants to
see them, let me know and I'll send them off-list.
The Fl_Window class inherits from Fl_group, which inherits from Fl_Widget.
The Fl_Box class inherits from Fl_Widget.
Thanks,
Mark
At 08:43 AM 2/21/2004 +1100, you wrote:
>Mark Mussetter wrote:
>>Hello Everyone,
>>I seem to be having trouble with operator "new" not allocating enough
>>memory for FLTK objects.  Displaying the sizeof the objects in the
>>debugger returns the correct size, but printing the sizeof the objects
>>from within the program gives the wrong result (it matches the amount of
>>space that "new" allocates).  We are using the V4.6pre5 m68k-rtems-gcc
>>compiler.  Is there something I could be doing wrong that would cause the
>>compiler to calculate the sizeof the object incorrectly?
>>#include <FL/Fl.H>
>>#include <FL/Fl_Window.H>
>>#include <FL/Fl_Box.H>
>>#include <stdio.h>
>I would need to see the class definitions (the headers)
>>extern "C" void startupLCD(void);
>>extern "C" void touchScreenInit(void);
>>extern "C" int rtems_main(int argc, char **argv);
>>int rtems_main(int argc, char **argv) {
>>         Fl_Window *window = new Fl_Window(200,180);
>>         Fl_Box *box = new Fl_Box(20,40,170,100,"Hello, World!");
>>         printf( "Sizeof(Fl_Window) = (0x%X) %d bytes\n",
>> sizeof(Fl_Window), sizeof(Fl_Window) );
>>         printf( "Sizeof(*window) = (0x%X) %d bytes\n", sizeof(*window),
>> sizeof(*window) );
>>         printf( "Sizeof(Fl_Box) = (0x%X) %d bytes\n", sizeof(Fl_Box),
>> sizeof(Fl_Box) );
>>         printf( "Sizeof(*box) = (0x%X) %d bytes\n", sizeof(*box),
>> sizeof(*box) );
>>         printf( "Address of *window = (0x%X) %d\n", window,window );
>>         printf( "Address of *box = (0x%X) %d\n", box,box );
>>         startupLCD();
>>         touchScreenInit();
>>         box->box(FL_UP_BOX);
>>         box->labelsize(36);
>>         box->labelfont(FL_BOLD+FL_ITALIC);
>>         //box->labeltype(FL_SHADOW_LABEL);
>>         window->end();
>>         window->show(argc, argv);
>>         return Fl::run();
>Angelo Fraietta
>PO Box 859
>Hamilton NSW 2303
>Home Page
>http://www.users.bigpond.com/angelo_f/
>There are those who seek knowledge for the sake of knowledge - that is
>CURIOSITY
>There are those who seek knowledge to be known by others - that is VANITY
>There are those who seek knowledge in order to serve - that is LOVE
>    Bernard of Clairvaux (1090 - 1153)
