some questions and bugs about the super core:
doclzs
doclzs at 163.com
Mon Feb 23 04:15:12 UTC 2004
Hi, here are some questions i have not understood
well:
(1)address.inl
RTEMS_INLINE_ROUTINE unsigned32 _Addresses_Subtract (
void *left,
void *right
return ((char *) left - (char *) right);
RTEMS_INLINE_ROUTINE boolean _Addresses_Is_in_range (
void *address,
void *base,
void *limit
return ( address >= base && address <= limit );
question:
in function "_Addresses_Subtract",the address
is converted into type (char*) but in function
"_Addresses_Is_in_range" not. why?
(2)bitfield.h
#define _Bitfield_Find_first_bit( _value, _bit_number ) \
register unsigned32 __value = (unsigned32) (_value); \
register const unsigned char *__p = __log2table; \
if ( __value < 0x100 ) \
(_bit_number) = __p[ __value ] + 8; \
else \
(_bit_number) = __p[ __value >> 8 ]; \
bug:
i think should be
register unsigned16 __value = (unsigned16) (_value);
(3)coremsg.h
typedef struct {
unsigned32 size;
unsigned32 buffer[1];
} CORE_message_queue_Buffer;
question:
typedef struct {
unsigned32 size;
unsigned32 *buffer;
is it right?
(4)heapallocate.c
if ( size >= (-1 - HEAP_BLOCK_USED_OVERHEAD) )
return( NULL );
excess = size % the_heap->page_size;
the_size = size + the_heap->page_size + HEAP_BLOCK_USED_OVERHEAD;
bug:
"size >= (-1 - HEAP_BLOCK_USED_OVERHEAD)",it is sure,right?
"the_size = size + the_heap->page_size + HEAP_BLOCK_USED_OVERHEAD",
i think it should be
"the_size = size + HEAP_BLOCK_USED_OVERHEAD"
(5)heapfree.c line 55
next_block = _Heap_Block_at( the_block, the_size );
bug:
it should be
next_block = _Heap_Next_block( the_block );
(6)priority.h line 61
SCORE_EXTERN Priority_Bit_map_control
_Priority_Bit_map[16] CPU_STRUCTURE_ALIGNMENT;
bug:
it should be
SCORE_EXTERN Priority_Bit_map_control _Priority_Bit_map[16];
(7)
the control block used to manage each watchdog timer
as follows:
typedef struct {
Chain_Node Node;
Watchdog_States state;
Watchdog_Interval initial;
Watchdog_Interval delta_interval;
Watchdog_Interval start_time;
Watchdog_Interval stop_time;
Watchdog_Service_routine_entry routine;
Objects_Id id;
void *user_data;
} Watchdog_Control;
question:
what is meaning of the variable "initial",
"delta_interval", "start_time" and "stop_time"?
what is the relation between
a watchdog's position on the chain and
the variable "delta_interval"?
网易VIP收费邮箱两周年超值优惠! 满1赠6!! http://vip.163.com
中国最大的免费邮箱在等你 25兆空间4兆附件! http://mail.163.com
点击网易泡泡惊喜无限 全免费手机短信任你发! http://popo.163.com
