gmake[2]: execvp: m68k-rtems-gcc: Too many levels of symbolic links
Mon Feb 23 22:28:58 UTC 2004
Gordon Scott wrote:
> On Mon, 23 Feb 2004, Ralf Corsepius wrote:
>>=> Your environment is screwed up.
> Well, a sparse hint but it looks enough.
> Amongst the things I considered was my PATH variable. This had two ~/bin
> entries, which seemed excessive and the /opt/rtems-4.6/bin was near the
> end of a fairly long string, so I moved it nearer the start.
In general, a short path is better than a long path for a number of
reasons. :)
I recommend putting the RTEMS directory first in your PATH as a general
rule because if you need the RTEMS speific automake or autoconf, then
it MUST be ahead of the system default.
> Not sure how this has changed things, but the make is up and runnign
> again.
> Thanks Ralf.
> 		Gordon.
