m68040 FPSP question
Chris Johns cjohns at cybertec.com.au
Wed Feb 25 04:22:14 UTC 2004
Till Straumann wrote:
> Again some nameclashes:
> FPSP exports a bunch of name-clash prone symbols,
> two of which actually clash with libm symbols:
>  'round' and 'sinf'
> The latter returns 'signed infinity' (FPSP)
> or a single precision sin()  (libm) !
> What to do?
Is the FPSP the software emulation of the instructions missing from the
68020 ?
If so then I suggest you consider using a -m68040 for newlib (which
should already be done) and RTEMS. This removes the need for any
emulation software.
IMO this library is only needed if you have a binary which needs to be
moved from the 68020 to the 68040.
I use a multilib RTEMS for the 68EC060 without any emulation and it
works fine (the EC does not have a FP unit so also have -msoft-float).
 > Are there any user-entry points to FPSP at all
 > (apart from the installation routine, of course)?
  Chris Johns, cjohns at cybertec . com . au
