Trouble building 4.6.0 for i386
Manuel Pedro Coutinho manuelpedrocoutinho at hotmail.com
Wed Feb 25 19:10:38 UTC 2004
Hi.
I'm new to RTEMS, but I have some experience with it ( I added a driver to
the pc386 board in the 4.5.0 release)
I'm currently trying to make a project with the NFS client and I saw that
the 4.6.0 release had it.
So, I built correctly (at least I think so) the cross-compiler and when
building RTEMS the following error arises:
configure: running /bin/sh
'../../../../../../../rtems-4.6.0/c/src/lib/libcpu/i386/configure'
--prefix=/home/manuel/rtems460/  '--prefix=/home/manuel/rtems460/'
'--host=i386-rtems' '--build=i686-pc-linux-gnu' '--target=i386-rtems'
'--enable-posix'
'--enable-cxx' '--with-target-subdir=i386-rtems'
'--exec-prefix=/home/manuel/rtems460//i386-rtems'
'build_alias=i686-pc-linux-gnu' 'host_alias=i386-rtems'
'target_alias=i386-rtems' 'RTEMS_BSP=pc386' 'RTEMS_CPU_MODEL=i386_fp'
'RTEMS_BSP_FAMILY=pc386' 'CFLAGS_OPTIMIZE_V=-O4' '--cache-file=/dev/null'
'--srcdir=../../../../../../rtems-4.6.0/c/src/lib/libcpu'
--srcdir=../../../../../../../rtems-4.6.0/c/src/lib/libcpu/i386
../../../../../../../rtems-4.6.0/c/src/lib/libcpu/i386/configure: line 1212:
syntax error near unexpected token `../../../../..'
`RTEMS_TOP(../../../../..)'
configure: error: /bin/sh
'../../../../../../../rtems-4.6.0/c/src/lib/libcpu/i386/configure' failed
for i386
'../../../../../../rtems-4.6.0/c/src/lib/libcpu/configure' failed for
lib/libcpu
gmake[2]: *** [pc386] Error 1
gmake[2]: Leaving directory
`/home/manuel/rtems460/tools/build-rtems/i386-rtems/c'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory
make: *** [all-recursive] Error 1
I tryed to solve the problem in line 1212 of  i386/configure but when I look
to the version 4.5.0 it is the same! So, I assumed that the problem wasn´t
in i386/configure but I can´ t solve it because I don´t know where to find
it
(I´m working on a Linux ReadHat 9.x)
I apreciate if anyone could help me...
Thanks
Manuel Coutinho
_________________________________________________________________
MSN Messenger: converse com os seus amigos online.
http://messenger.msn.com.br
