Trouble building 4.6.0 for i386
Adriano Verardo a.verardo at tecmav.fastwebnet.it
Thu Feb 26 19:14:36 UTC 2004
Manuel Pedro Coutinho wrote:
>> From: Ralf Corsepius <corsepiu at faw.uni-ulm.de>
>> To: Manuel Pedro Coutinho <manuelpedrocoutinho at hotmail.com>
>> CC: RTEMS Users <rtems-users at rtems.com>
>> Subject: Re: Trouble building 4.6.0 for i386
>> Date: Wed, 25 Feb 2004 21:59:42 +0100
>> On Wed, 2004-02-25 at 20:10, Manuel Pedro Coutinho wrote:
>> > Hi.
>> > I'm new to RTEMS, but I have some experience with it ( I added a
>> driver to
>> > the pc386 board in the 4.5.0 release)
>> > I'm currently trying to make a project with the NFS client and I
>> saw that
>> > the 4.6.0 release had it.
>> > So, I built correctly (at least I think so) the cross-compiler and
>> when
>> > building RTEMS the following error arises:
>> > configure: running /bin/sh
>> > '../../../../../../../rtems-4.6.0/c/src/lib/libcpu/i386/configure'
>> > --prefix=/home/manuel/rtems460/  '--prefix=/home/manuel/rtems460/'
>> > '--host=i386-rtems' '--build=i686-pc-linux-gnu' '--target=i386-rtems'
>> > '--enable-posix'
>> > '--enable-cxx' '--with-target-subdir=i386-rtems'
>> > '--exec-prefix=/home/manuel/rtems460//i386-rtems'
>> > 'build_alias=i686-pc-linux-gnu' 'host_alias=i386-rtems'
>> > 'target_alias=i386-rtems' 'RTEMS_BSP=pc386' 'RTEMS_CPU_MODEL=i386_fp'
>> > 'RTEMS_BSP_FAMILY=pc386' 'CFLAGS_OPTIMIZE_V=-O4'
>> '--cache-file=/dev/null'
>> > '--srcdir=../../../../../../rtems-4.6.0/c/src/lib/libcpu'
>> > --srcdir=../../../../../../../rtems-4.6.0/c/src/lib/libcpu/i386
>> > ../../../../../../../rtems-4.6.0/c/src/lib/libcpu/i386/configure:
>> line 1212:
>> > syntax error near unexpected token `../../../../..'
>> line 1212:
>> > `RTEMS_TOP(../../../../..)'
>> > configure: error: /bin/sh
>> failed
>> > for i386
>> > '../../../../../../rtems-4.6.0/c/src/lib/libcpu/configure' failed for
>> > lib/libcpu
>> > gmake[2]: *** [pc386] Error 1
>> > gmake[2]: Leaving directory
>> > `/home/manuel/rtems460/tools/build-rtems/i386-rtems/c'
>> > gmake[1]: *** [all-recursive] Error 1
>> > gmake[1]: Leaving directory
>> > make: *** [all-recursive] Error 1
>> > I tryed to solve the problem in line 1212 of  i386/configure but
>> when I look
>> > to the version 4.5.0 it is the same! So, I assumed that the problem
>> wasn´t
>> > in i386/configure but I can´ t solve it because I don´t know
>> where to find
>> > it
>> > (I´m working on a Linux ReadHat 9.x)
>> > I apreciate if anyone could help me...
>> A file is missing from the tarball:
>> http://www.rtems.com/cgi-bin/gnatsweb.pl?database=RTEMS&cmd=view&pr=574
>> Ralf
> Hi again
> I´ve copied the new version of libcpu/i386/Makefile.in and it still
> doesn't work!!!
> (I've also copied ChangeLog)
> _________________________________________________________________
> MSN Hotmail, o maior webmail do Brasil. http://www.hotmail.com
I've copied the files configure and Makefile.in from
c/src/lib/libcpu/i386 of the v460pre5 tarball
into the v460 tree.  This way  the building (seems to) have no problems,
but I have not tried
any application yet.
I've not
