file system
Ed Sutter
els at emailbox.hdtv.lucent.com
Mon Feb 2 14:54:34 UTC 2004
Pete,
I run RTEMS with MicroMonitor underneath. Provides an immediate
flash file system (read/write) for RTEMS-based applications.
If you're able to shift to MicroMonitor as your bootloader,
let me know and I'll be glad to give you details.
Ed Sutter
"D. Peter Siddons" wrote:
> Hi all,
> I have an RTEMS application which resides in flash memory, and
> expects to read a configuration file at startup. It currently does this
> via tftp from a networked server, which works fine. I'd really like to
> make this thing stand-alone, so ideally it would read this information
> from some kind of local filesystem. There is enough capacity in the
> on-board flash memory if I could set up a filesystem in there; even more
> so if it could be compressed. It need only be read-only. Has anyone else
> done something similar? I've seen all the postings re compact flash, but
> I don't think that is at all the same.
> Thanks,
> Pete.
> D. Peter Siddons
> Bldg. 725D, NSLS
> Brookhaven National Laboratory
> Upton, NY 11976
> USA.
> Email: siddons at bnl.gov
