file system
gregory.menke at gsfc.nasa.gov
Mon Feb 2 15:14:52 UTC 2004
I'd like some details about Micromonitor too- we have a similar need
at the moment.
Thanks,
Gregm
Ed Sutter writes:
> Pete,
> I run RTEMS with MicroMonitor underneath. Provides an immediate
> flash file system (read/write) for RTEMS-based applications.
> If you're able to shift to MicroMonitor as your bootloader,
> let me know and I'll be glad to give you details.
> Ed Sutter
> "D. Peter Siddons" wrote:
> > Hi all,
> > I have an RTEMS application which resides in flash memory, and
> > expects to read a configuration file at startup. It currently does this
> > via tftp from a networked server, which works fine. I'd really like to
> > make this thing stand-alone, so ideally it would read this information
> > from some kind of local filesystem. There is enough capacity in the
> > on-board flash memory if I could set up a filesystem in there; even more
> > so if it could be compressed. It need only be read-only. Has anyone else
> > done something similar? I've seen all the postings re compact flash, but
> > I don't think that is at all the same.
> > Thanks,
> > Pete.
> > D. Peter Siddons
> > Bldg. 725D, NSLS
> > Brookhaven National Laboratory
> > Upton, NY 11976
> > USA.
> > Email: siddons at bnl.gov
