some newbie questions
sebastian ssmoller
sebastian.ssmoller at gmx.net
Sat Feb 14 07:28:49 UTC 2004
On Fri, 13 Feb 2004 15:46:42 -0500 (EST)
gregory.menke at gsfc.nasa.gov wrote:
> sebastian ssmoller writes:
> > sure :)
> > i am looking at c/src/lib/libbsp/m68k/gen68360/console/console.c
> > and its
> > dependencies (esp. m68360.h). i find that code easy to read in and
> > that
> > helps a lot. the problem is that there are a lot of references to
> > other
> > parts of the os.
> > e.g.: m68360.h defines a struct m360_t and a variable m360 in this
> > way: extern volatile m360_t m360;
> > cause m360 is defined extern there must by some definition of that
> > variable, right ? so i grep'ed the whole source tree but havnt
> > found
> > that definition yet.
> Be sure to check at the top level, down in c/src or below misses a
> whole bunch of OS content (most of it in fact). I don't believe an
> extern requires the variable actually be used- be sure to check ALL
> files, not just .c- its quite amazing where some things end up.
i guess i did. what i do is the following:
$ cd /path/to/rtems (rtems-ss-20030703)
$ ls
COPYING README.cdn-X c install-sh
ChangeLog README.configure config-ml.in make
INSTALL SUPPORT config.guess mdate-sh
LICENSE VERSION config.sub missing
LICENSE.NET acinclude.m4 configure mkinstalldirs
LICENSE.RPCXDR aclocal configure.ac scripts
LICENSE.WEBSERVER aclocal.m4 contrib texinfo.tex
Makefile.am autom4te.cache cpukit tools
Makefile.in automake depcomp
README bootstrap doc
$ grep -r m360_t *
cpukit/score/cpu/m68k/m68360.h:} m360_t;
cpukit/score/cpu/m68k/m68360.h:extern volatile m360_t m360;
this variable (m360) is havily used in console.c. so it must be defined
somewhere, or not ?
> > another question: how often is the interrupt-handler called ? each
> > time
> > a new byte is received via serial port ?
> As always, it depends. If the console port is interrupt driven, then
> yes- once per char. Not all consoles are, the MongooseV bsp uses a
> polled uart because of interrupt servicing overhead.
ok. thx
> > ok i will think about that. i am not sure if this is an option for
> > me. i
> > will have a deeper look at this stuff. thx
> Please give an example of various events you would use to schedule
> tasks.
> If you're trying to schedule tasks as a consequence of receiving
> particular CAN messages, that is very much a userspace issue. Perhaps
> a driver could be written allowing the user to provide tasks that are
> associated with CAN messages, but that has nothing directly to do with
> the OS scheduler. Each task would sleep until awoken by the interrupt
> service routine the message the task is waiting for is received- the
> rtems event signalling primitives would be suitable for that.
sounds interesting. thats exactly what i wonna do. i try to schedule the
system (the tasks) via CAN messages.
> > > "sending messages" is too vague as far as integrating with the
> > > kernel.
> > > There's nothing stopping you from implementing a CAN driver via a
> > > /proc file and interacting with it via file handles- just like
> > > Linux,
> > > etc does. Its a bit easier to put that stuff in your application
> > > until you have something general purpose enough to make a device
> > > driver. OTOH, if you do implement some kind of CAN hardware
> > > support,
> > > then the RTEMS community would very much welcome its inclusion in
> > > the
> > > source tree.
> > what i need is a driver which supports sending and reveiving CAN
> > frames.
> > therefore i need an interrupt handler, too. in general a CAN driver
> > depends on the vendor specific "implementation" of the CAN spec.
> > i use TIP816 from "Tews datentechnik".
> > because of this hardware dependencies in unix like OSes i would put
> > such
> > a driver into kernel space.
> bsp's offer various forms of interrupt vector management- you supply
> some form of interrupt descriptor (usually a #define representing a
> particular interrupt vector), and a C routine to call when the
> interrupt occurs- RTEMS handles the context save/restores, your code
> just manipulates the device hardware. Some bsp's use the simple
> vectoring concept that RTEMS supplies by default, others get fancier.
> If you track down how your bsp sets up the clock tick interrupt,
> you'll get a hint as to how that bsp handles vectors. There is no
> alternative to knowing how the device in question is wired to the
> interrupt control unit on the processor. If you can't answer that
> question, you can't choose the right interrupt vector for your driver.
> RTEMS bsp's that support PCI subsystems make that task easier for the
> user.
> Remember, RTEMS is very efficient at context switching, so its
> entirely reasonable to poll hardware in a high priority task thats
> woken up by the user whenever something should happen. The network
> drivers take this approach- along with various forms of interrupt
> service routines.
> I'd suggest implementing your driver in user code, calling it directly
> to do things until it has a coherent interface thats suited for
> inclusion as an OS driver. RTEMS does not distinguish between kernel
> and user space- there is no trap interface or "kernel mode". The
> terms are used loosely to represent RTEMS OS code vs user code- but it
> all runs in one flat address space.
ok. again thx for all these helpful info.
regards,
seb
> Gregm
Microsoft: Where do you want to go today?
Linux: Where do you want to go tomorrow?
FreeBSD: Are you guys coming or what?
OpenBSD: Hey guys you left some holes out there!
