how to create gdb simulator for a new board
Joel Sherrill
joel.sherrill at oarcorp.com
Tue Feb 17 11:51:56 UTC 2004
durai wrote:
>Hi,
> I want to debug/run the rtems sample applications without the real hardware
>present.
>My CPU is mips R3000 core. How to create a mips-rtems-gdb for my board?
>How to add new peripherals such as timer, console in to the gdb simulator?
>please let me know from where should i start.
Do you want an accurate simulator for your board and all peripherals or
just something
good enough to run basic applications?
The jmr3904 BSP already exists and matches a simulator configuration in
gdb for an
eval board for the Toshiba TX3904. It is an R3000 with a clock and console.
>thanks & regards
>durai
--joel
