volatile in struct
Eric Norum
norume at aps.anl.gov
Wed Feb 18 13:07:25 UTC 2004
On Feb 18, 2004, at 2:50 AM, Sergei Organov wrote:
> Juergen Zeller <juergen.zeller at argovision.de> writes:
>> Thank you for all your statements. But this is not the key for my
>> question.
>> Unfortunately somebody cut out my first mail, so I'm not wondering
>> something
>> 'other' is discussed. Here my first questiion again:
> It has been answered already. Here is the initial answer:
> 1. You should protect your shared data with *the same* primitive in
> all the
> threads. Either use rtems_interrupt_x in both threads or use
> rtems_semaphore_x in both threads.
> 2. Using volatile is almost never a good idea. If you use RTOS
> primitives for
> mutual exclusion correctly, you don't need volatile for your
> protected
> data.
All-encompassing statements like 'almost a never a good idea' are
likely to confuse the novice. Yes, using volatile variables is
probably not a good way to share data among tasks. But volatile is
absolutely necessary when working with 'variables' that are actually
I/O registers.
Eric Norum <norume at aps.anl.gov>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
