some newbie questions
    sebastian ssmoller
    sebastian.ssmoller at gmx.net
    Wed Feb 18 19:12:04 UTC 2004
On Wed, 18 Feb 2004 12:53:46 -0600
Joel Sherrill <joel.sherrill at OARcorp.com> wrote:
> Ed Sutter wrote:
> > Seb,
> > You can't call something with printf() in it at this level.
> > Think about it...
> > The guts of printf() requires console IO to be working.
> > Console IO is likely handled by the serial port device
> > driver in RTEMS.  Since we're side-stepping the whole
> > RTOS startup here,  printf() will certainly not work.
> But printk probably will if you have a stack and the
> BSP output char hook filled it.
this approach (and the other one, too) sound interesting. i will have a
look at it tomorrow. thx
regards,
seb
> --joel
> > Ed
> > sebastian ssmoller wrote:
> >>hi,
> >>using an "independent" function is of cause a good idea :)
> >>calling this funct does NOT cause the board to hang - so this is one
> >step>into the right direction :)
> >>i wasnt able yet to get the value of the variable - i have to read some
> >>docs about the monitor first.
> >>but what i did is, i only include a printf (which causes to inlcude and
> >use>lots of other stuff of course). calling the funct again caused a bus
> >error.>next pc points into the fstat function ...
> >>this let me believe that my linkcmds file is not correct. so possibly u
> >>could have a look at it ?
> >>====== linkcmds from intro (which works) =========
> >>// This linker command file was created by Introl-CODE.
> >>// Library modules used by this program
> >>// Program memory groups
> >>group ROM rom itemalign 2 origin 0x0700 maxsize 0x10000-0x0700;
> >>    section .vectors data;
> >>    section .start0 text;
> >>    section .start1 text;
> >>    section .start2 text;
> >>    section .start3 text;
> >>    section .start4 text;
> >>    section .start5 text;
> >>    section .start6 text;
> >>    section .start7 text;
> >>    section .start8 text;
> >>    section .start9 text;
> >>    section .startX text;
> >>    section .startZ text;
> >>    section ROM.const data = .const .strings;
> >>    section ROM.text text = .text;
> >>    section .init;
> >>group ROM;
> >>set __ROMstart = 0x0700;
> >>set __ROMend = 0x10000;
> >>set __ROMsize = 0x10000-0x0700;
> >>group RAM ram bss itemalign 2 origin 0x10000 maxsize 0x50000-0x10000;
> >>    section .bss comms;
> >>    section .data data copiedfrom .init;
> >>    section .retm comm;
> >>    section .heap expand minsize 0;
> >>    section .stack minsize 0;
> >>    section RAM.ubss = .ubss;
> >>group RAM;
> >>set __RAMstart = 0x10000;
> >>set __RAMend = 0x50000;
> >>set __RAMsize = 0x50000-0x10000;
> >>group IO io bss origin 0xFFF000 maxsize 0x1000000-0xFFF000;
> >>    section .chip;
> >>group IO;
> >>set __IOstart = 0xFFF000;
> >>set __IOend = 0x1000000;
> >>set __IOsize = 0x1000000-0xFFF000;
> >>// Link time variable definitions
> >>set __ramstart = startof(.bss);
> >>set __ramend = endof(.bss);
> >>set __heapstart = startof(.heap);
> >>set __heapend = endof(.heap);
> >>set __stackstart = startof(.stack);
> >>set __stackend = endof(.stack);
> >>set __initstart = startof(.init);
> >>set __initend = endof(.init);
> >>set __datastart = startof(.data);
> >>set __dataend = endof(.data);
> >>set __fastend = endof(.start1);
> >>set __chipstart = startof(.chip);
> >>readline;       // Read files from the command line
> >>end;
> >>============ linkcmds intro end ==================
> >>============ linkcmds from rtems (with memory values changed) ========
> >> * This file contains GNU linker directives for a generic MC68360
> >board.> * Variations in memory size and allocation can be made by
> >> * overriding some values with linker command-line arguments.
> >> * Saskatchewan Accelerator Laboratory
> >> * University of Saskatchewan
> >> * Saskatoon, Saskatchewan, CANADA
> >> * eric at skatter.usask.ca
> >> *  linkcmds,v 1.20 2003/01/20 20:19:44 joel Exp
> >>OUTPUT_FORMAT("srec");
> >> * Declare some sizes.
> >> * A heap size of 0 means `use all available memory for the heap'.
> >>_RamBase = DEFINED(_RamBase) ? _RamBase : 0x10000;
> >>_RamSize = DEFINED(_RamSize) ? _RamSize : 0x50000-0x10000;
> >>_HeapSize = DEFINED(_HeapSize) ? _HeapSize : 0x0;
> >>_StackSize = DEFINED(_StackSize) ? _StackSize : 0x1000;
> >> * Declare on-board memory.
> >>MEMORY {
> >>          rom : ORIGIN = 0x0700,  LENGTH = 0x10000 - 0x0700
> >>          ram : ORIGIN = 0x10000, LENGTH = 0x50000 - 0x10000
> >>        dpram : ORIGIN = 0xFFC00001, LENGTH = 0xFFC02000 - 0xFFC00000
> >> * Load objects
> >>SECTIONS {
> >>         * Boot PROM
> >>        rom : {
> >>                _RomBase = .;
> >>        } >rom
> >>         * Dynamic RAM
> >>        ram : {
> >>                _RamBase = .;
> >>        } >ram
> >>         * Text, data and bss segments
> >>        .text : {
> >>                *(.text)
> >>                         * C++ constructors/destructors
> >>                        *(.gnu.linkonce.t.*)
> >>                         * Initialization and finalization code.
> >>                        PROVIDE (_init = .);
> >>                        *crti.o(.init)
> >>                        *(.init)
> >>                        *crtn.o(.init)
> >>                        PROVIDE (_fini = .);
> >>                        *crti.o(.fini)
> >>                        *(.fini)
> >>                        *crtn.o(.fini)
> >>                         * Special FreeBSD sysctl sections.
> >>                        . = ALIGN (16);
> >>                        __start_set_sysctl_set = .;
> >>                        *(set_sysctl_*);
> >>                        __stop_set_sysctl_set = ABSOLUTE(.);
> >>                        *(set_domain_*);
> >>                        *(set_pseudo_*);
> >>                        . = ALIGN (16);
> >>                        *crtbegin.o(.ctors)
> >>                        *(.ctors)
> >>                        *crtend.o(.ctors)
> >>                        *crtbegin.o(.dtors)
> >>                        *(.dtors)
> >>                        *crtend.o(.dtors)
> >>                         * Exception frame info
> >>                        . = ALIGN (16);
> >>                        *(.eh_frame)
> >>                         * Read-only data
> >>                        . = ALIGN (16);
> >>                        _rodata_start = . ;
> >>                        *(.rodata*)
> >>                        *(.gnu.linkonce.r*)
> >>                 . = ALIGN (16);
> >>                PROVIDE (etext = .);
> >>        } >ram
> >>        .data : {
> >>                _copy_start = .;
> >>                *(.data)
> >>                        *(.gnu.linkonce.d*)
> >>                        *(.gcc_except_table)
> >>                        *(.jcr)
> >>                . = ALIGN (16);
> >>                PROVIDE (edata = .);
> >>                _copy_end = .;
> >>        } >ram
> >>        .bss : {
> >>                M68Kvec = .;
> >>                . += (256 * 4);
> >>                _clear_start = .;
> >>                *(.bss)
> >>                *(COMMON)
> >>                . = ALIGN (16);
> >>                PROVIDE (end = .);
> >>                . += _StackSize;
> >>                . = ALIGN (16);
> >>                _stack_init = .;
> >>                _clear_end = .;
> >>                _WorkspaceBase = .;
> >>                variable = .;
> >>        } >ram
> >>         * On-chip memory/peripherals
> >>        dpram : {
> >>                m360 = .;
> >>                . += (8 * 1024);
> >>        } >dpram
> >>  /* Stabs debugging sections.  */
> >>  .stab 0 : { *(.stab) }
> >>  .stabstr 0 : { *(.stabstr) }
> >>  .stab.excl 0 : { *(.stab.excl) }
> >>  .stab.exclstr 0 : { *(.stab.exclstr) }
> >>  .stab.index 0 : { *(.stab.index) }
> >>  .stab.indexstr 0 : { *(.stab.indexstr) }
> >>  .comment 0 : { *(.comment) }
> >>  /* DWARF debug sections.
> >>     Symbols in the DWARF debugging sections are relative to the
> >beginning>     of the section so we begin them at 0.  */
> >>  /* DWARF 1 */
> >>  .debug          0 : { *(.debug) }
> >>  .line           0 : { *(.line) }
> >>  /* GNU DWARF 1 extensions */
> >>  .debug_srcinfo  0 : { *(.debug_srcinfo) }
> >>  .debug_sfnames  0 : { *(.debug_sfnames) }
> >>  /* DWARF 1.1 and DWARF 2 */
> >>  .debug_aranges  0 : { *(.debug_aranges) }
> >>  .debug_pubnames 0 : { *(.debug_pubnames) }
> >>  /* DWARF 2 */
> >>  .debug_info     0 : { *(.debug_info) }
> >>  .debug_abbrev   0 : { *(.debug_abbrev) }
> >>  .debug_line     0 : { *(.debug_line) }
> >>  .debug_frame    0 : { *(.debug_frame) }
> >>  .debug_str      0 : { *(.debug_str) }
> >>  .debug_loc      0 : { *(.debug_loc) }
> >>  .debug_macinfo  0 : { *(.debug_macinfo) }
> >>  /* SGI/MIPS DWARF 2 extensions */
> >>  .debug_weaknames 0 : { *(.debug_weaknames) }
> >>  .debug_funcnames 0 : { *(.debug_funcnames) }
> >>  .debug_typenames 0 : { *(.debug_typenames) }
> >>  .debug_varnames  0 : { *(.debug_varnames) }
> >>  /* These must appear regardless of  .  */
> >>============ linkcmds rtems end ==================
> >>i checked the "ca" (call) syntax again and i guess it is correct, cause
> >it>works with introl code and when calling the unique_function
> >>many thx again
> >>regards,
> >>seb
> >>On Wed, 18 Feb 2004 12:14:30 -0500
> >>Ed Sutter <els at emailbox.hdtv.lucent.com> wrote:
> >>>Seb,
> >>>Try starting with something simpler.
> >>>Here's a few suggestions...
> >>>In your application add a function and a variable..
> >>>long unique_variable;
> >>>long
> >>>unique_function(void)
> >>>      return(++unique_variable);
> >>>Then load your application and instead of calling the entrypoint,
> >>>parse your symbol table and call this function's address.  If this
> >>>hangs, you have a more fundamental problem, if it doesn't hang
> >>>the do some more investigation...
> >>>If the "call" command that you have shows the return value of the
> >>>function you called, then you should notice it incrementing.
> >>>If the "call" command doesn't support that, then call the function
> >>>and then display the variable using some other monitor command.
> >>>Another thing to try would be to disassemble the the address of
> >>>the application entrypoint and see if it makes sense.
> >>>The point here is to test some of the stuff outside of RTEMS.
> >>>Make sure your "call" command is working the way you think, etc...
> >>>For example, maybe "call" gets confused if your address is not
> >prefixed>>with "0x".  Or, maybe it gets confused if yoru address IS
> >>>Get the idea? These things will just give you a confidence level
> >>>(maybe good maybe not so good) in what you're doing.
> >>>Ed
