some newbie questions
Ed Sutter
els at emailbox.hdtv.lucent.com
Wed Feb 18 19:18:32 UTC 2004
On the other hand, if printk() works, then you're much
futher along than originally suspected, so try that first.
Ed
Ed Sutter wrote:
> This is true, however, even printk() requires some of the
> basic initialization of the system's low level stuff
> to complete (right?), and at this point, it sounds like all
> bets are off. As of this morning, the location of the
> entrypoint was an unknown, so it seems like best approach
> at this point is to assume nothing.
> Joel Sherrill wrote:
> > Ed Sutter wrote:
> > > Seb,
> > > You can't call something with printf() in it at this level.
> > > Think about it...
> > > The guts of printf() requires console IO to be working.
> > > Console IO is likely handled by the serial port device
> > > driver in RTEMS. Since we're side-stepping the whole
> > > RTOS startup here, printf() will certainly not work.
> > But printk probably will if you have a stack and the
> > BSP output char hook filled it.
> > --joel
> > > Ed
> > > sebastian ssmoller wrote:
> > >>hi,
> > >>using an "independent" function is of cause a good idea :)
> > >>calling this funct does NOT cause the board to hang - so this is one step
> > >>into the right direction :)
> > >>i wasnt able yet to get the value of the variable - i have to read some
> > >>docs about the monitor first.
> > >>but what i did is, i only include a printf (which causes to inlcude and use
> > >>lots of other stuff of course). calling the funct again caused a bus error.
> > >>next pc points into the fstat function ...
> > >>this let me believe that my linkcmds file is not correct. so possibly u
> > >>could have a look at it ?
> > >>====== linkcmds from intro (which works) =========
> > >>// This linker command file was created by Introl-CODE.
> > >>// Library modules used by this program
> > >>// Program memory groups
> > >>group ROM rom itemalign 2 origin 0x0700 maxsize 0x10000-0x0700;
> > >> section .vectors data;
> > >> section .start0 text;
> > >> section .start1 text;
> > >> section .start2 text;
> > >> section .start3 text;
> > >> section .start4 text;
> > >> section .start5 text;
> > >> section .start6 text;
> > >> section .start7 text;
> > >> section .start8 text;
> > >> section .start9 text;
> > >> section .startX text;
> > >> section .startZ text;
> > >> section ROM.const data = .const .strings;
> > >> section ROM.text text = .text;
> > >> section .init;
> > >>group ROM;
> > >>set __ROMstart = 0x0700;
> > >>set __ROMend = 0x10000;
> > >>set __ROMsize = 0x10000-0x0700;
> > >>group RAM ram bss itemalign 2 origin 0x10000 maxsize 0x50000-0x10000;
> > >> section .bss comms;
> > >> section .data data copiedfrom .init;
> > >> section .retm comm;
> > >> section .heap expand minsize 0;
> > >> section .stack minsize 0;
> > >> section RAM.ubss = .ubss;
> > >>group RAM;
> > >>set __RAMstart = 0x10000;
> > >>set __RAMend = 0x50000;
> > >>set __RAMsize = 0x50000-0x10000;
> > >>group IO io bss origin 0xFFF000 maxsize 0x1000000-0xFFF000;
> > >> section .chip;
> > >>group IO;
> > >>set __IOstart = 0xFFF000;
> > >>set __IOend = 0x1000000;
> > >>set __IOsize = 0x1000000-0xFFF000;
> > >>// Link time variable definitions
> > >>set __ramstart = startof(.bss);
> > >>set __ramend = endof(.bss);
> > >>set __heapstart = startof(.heap);
> > >>set __heapend = endof(.heap);
> > >>set __stackstart = startof(.stack);
> > >>set __stackend = endof(.stack);
> > >>set __initstart = startof(.init);
> > >>set __initend = endof(.init);
> > >>set __datastart = startof(.data);
> > >>set __dataend = endof(.data);
> > >>set __fastend = endof(.start1);
> > >>set __chipstart = startof(.chip);
> > >>readline; // Read files from the command line
> > >>end;
> > >>============ linkcmds intro end ==================
> > >>============ linkcmds from rtems (with memory values changed) ========
> > >> * This file contains GNU linker directives for a generic MC68360 board.
> > >> * Variations in memory size and allocation can be made by
> > >> * overriding some values with linker command-line arguments.
> > >> * Saskatchewan Accelerator Laboratory
> > >> * University of Saskatchewan
> > >> * Saskatoon, Saskatchewan, CANADA
> > >> * eric at skatter.usask.ca
> > >> * linkcmds,v 1.20 2003/01/20 20:19:44 joel Exp
> > >>OUTPUT_FORMAT("srec");
> > >> * Declare some sizes.
> > >> * A heap size of 0 means `use all available memory for the heap'.
> > >>_RamBase = DEFINED(_RamBase) ? _RamBase : 0x10000;
> > >>_RamSize = DEFINED(_RamSize) ? _RamSize : 0x50000-0x10000;
> > >>_HeapSize = DEFINED(_HeapSize) ? _HeapSize : 0x0;
> > >>_StackSize = DEFINED(_StackSize) ? _StackSize : 0x1000;
> > >> * Declare on-board memory.
> > >>MEMORY {
> > >> rom : ORIGIN = 0x0700, LENGTH = 0x10000 - 0x0700
> > >> ram : ORIGIN = 0x10000, LENGTH = 0x50000 - 0x10000
> > >> dpram : ORIGIN = 0xFFC00001, LENGTH = 0xFFC02000 - 0xFFC00000
> > >> * Load objects
> > >>SECTIONS {
> > >> * Boot PROM
> > >> rom : {
> > >> _RomBase = .;
> > >> } >rom
> > >> * Dynamic RAM
> > >> ram : {
> > >> _RamBase = .;
> > >> } >ram
> > >> * Text, data and bss segments
> > >> .text : {
> > >> *(.text)
> > >> * C++ constructors/destructors
> > >> *(.gnu.linkonce.t.*)
> > >> * Initialization and finalization code.
> > >> PROVIDE (_init = .);
> > >> *crti.o(.init)
> > >> *(.init)
> > >> *crtn.o(.init)
> > >> PROVIDE (_fini = .);
> > >> *crti.o(.fini)
> > >> *(.fini)
> > >> *crtn.o(.fini)
> > >> * Special FreeBSD sysctl sections.
> > >> . = ALIGN (16);
> > >> __start_set_sysctl_set = .;
> > >> *(set_sysctl_*);
> > >> __stop_set_sysctl_set = ABSOLUTE(.);
> > >> *(set_domain_*);
> > >> *(set_pseudo_*);
> > >> . = ALIGN (16);
> > >> *crtbegin.o(.ctors)
> > >> *(.ctors)
> > >> *crtend.o(.ctors)
> > >> *crtbegin.o(.dtors)
> > >> *(.dtors)
> > >> *crtend.o(.dtors)
> > >> * Exception frame info
> > >> . = ALIGN (16);
> > >> *(.eh_frame)
> > >> * Read-only data
> > >> . = ALIGN (16);
> > >> _rodata_start = . ;
> > >> *(.rodata*)
> > >> *(.gnu.linkonce.r*)
> > >> . = ALIGN (16);
> > >> PROVIDE (etext = .);
> > >> } >ram
> > >> .data : {
> > >> _copy_start = .;
> > >> *(.data)
> > >> *(.gnu.linkonce.d*)
> > >> *(.gcc_except_table)
> > >> *(.jcr)
> > >> . = ALIGN (16);
> > >> PROVIDE (edata = .);
> > >> _copy_end = .;
> > >> } >ram
> > >> .bss : {
> > >> M68Kvec = .;
> > >> . += (256 * 4);
> > >> _clear_start = .;
> > >> *(.bss)
> > >> *(COMMON)
> > >> . = ALIGN (16);
> > >> PROVIDE (end = .);
> > >> . += _StackSize;
> > >> . = ALIGN (16);
> > >> _stack_init = .;
> > >> _clear_end = .;
> > >> _WorkspaceBase = .;
> > >> variable = .;
> > >> } >ram
> > >> * On-chip memory/peripherals
> > >> dpram : {
> > >> m360 = .;
> > >> . += (8 * 1024);
> > >> } >dpram
> > >> /* Stabs debugging sections. */
> > >> .stab 0 : { *(.stab) }
> > >> .stabstr 0 : { *(.stabstr) }
> > >> .stab.excl 0 : { *(.stab.excl) }
> > >> .stab.exclstr 0 : { *(.stab.exclstr) }
> > >> .stab.index 0 : { *(.stab.index) }
> > >> .stab.indexstr 0 : { *(.stab.indexstr) }
> > >> .comment 0 : { *(.comment) }
> > >> /* DWARF debug sections.
> > >> Symbols in the DWARF debugging sections are relative to the beginning
> > >> of the section so we begin them at 0. */
> > >> /* DWARF 1 */
> > >> .debug 0 : { *(.debug) }
> > >> .line 0 : { *(.line) }
> > >> /* GNU DWARF 1 extensions */
> > >> .debug_srcinfo 0 : { *(.debug_srcinfo) }
> > >> .debug_sfnames 0 : { *(.debug_sfnames) }
> > >> /* DWARF 1.1 and DWARF 2 */
> > >> .debug_aranges 0 : { *(.debug_aranges) }
> > >> .debug_pubnames 0 : { *(.debug_pubnames) }
> > >> /* DWARF 2 */
> > >> .debug_info 0 : { *(.debug_info) }
> > >> .debug_abbrev 0 : { *(.debug_abbrev) }
> > >> .debug_line 0 : { *(.debug_line) }
> > >> .debug_frame 0 : { *(.debug_frame) }
> > >> .debug_str 0 : { *(.debug_str) }
> > >> .debug_loc 0 : { *(.debug_loc) }
> > >> .debug_macinfo 0 : { *(.debug_macinfo) }
> > >> /* SGI/MIPS DWARF 2 extensions */
> > >> .debug_weaknames 0 : { *(.debug_weaknames) }
> > >> .debug_funcnames 0 : { *(.debug_funcnames) }
> > >> .debug_typenames 0 : { *(.debug_typenames) }
> > >> .debug_varnames 0 : { *(.debug_varnames) }
> > >> /* These must appear regardless of . */
> > >>============ linkcmds rtems end ==================
> > >>i checked the "ca" (call) syntax again and i guess it is correct, cause it
> > >>works with introl code and when calling the unique_function
> > >>many thx again
> > >>regards,
> > >>seb
> > >>On Wed, 18 Feb 2004 12:14:30 -0500
> > >>Ed Sutter <els at emailbox.hdtv.lucent.com> wrote:
> > >>>Seb,
> > >>>Try starting with something simpler.
> > >>>Here's a few suggestions...
> > >>>In your application add a function and a variable..
> > >>>long unique_variable;
> > >>>long
> > >>>unique_function(void)
> > >>> return(++unique_variable);
> > >>>Then load your application and instead of calling the entrypoint,
> > >>>parse your symbol table and call this function's address. If this
> > >>>hangs, you have a more fundamental problem, if it doesn't hang
> > >>>the do some more investigation...
> > >>>If the "call" command that you have shows the return value of the
> > >>>function you called, then you should notice it incrementing.
> > >>>If the "call" command doesn't support that, then call the function
> > >>>and then display the variable using some other monitor command.
> > >>>Another thing to try would be to disassemble the the address of
> > >>>the application entrypoint and see if it makes sense.
> > >>>The point here is to test some of the stuff outside of RTEMS.
> > >>>Make sure your "call" command is working the way you think, etc...
> > >>>For example, maybe "call" gets confused if your address is not prefixed
> > >>>with "0x". Or, maybe it gets confused if yoru address IS prefixed
> > >>>with "0x".
> > >>>Get the idea? These things will just give you a confidence level
> > >>>(maybe good maybe not so good) in what you're doing.
> > >>>Ed
