mbar and bus error (was: some newbie questions)
Ed Sutter
els at emailbox.hdtv.lucent.com
Mon Feb 23 13:08:08 UTC 2004
Did you verify whether or not access to MBAR requires supervisor level?
And then, whether or not your monitor is running at supervisor level?
Ed
sebastian ssmoller wrote:
> hi,
> during the last days i tried to access MBAR on my board (68360/040).
> without any success. even read access causes a bus error :(
> i reread the doc of my board and the quicc (6.8, 9.2, 4.4.3, 6.9.1, aso)
> and i guess the initialisation sequence i use is correct.
> i also downloaded the linux kernel (2.6.3) and had a look at the init
> sequence used there - it is more or less the same.
> i googled around for some hours - the sample code/doc i found uses the same
> init seq as rtems/linux/my test prog.
> i wrote simple asm prog to isolate the problematic code - no success.
> thats the code:
> start:
> movel #0,dptr /* my debug var to see where the prog hangs */
> movel #0,dptr+4
> movel #0,dptr+8
> /* SSP */
> oriw #0x3000,sr | Switch to Master Stack Pointer
> oriw #0x2700,sr
> movea.l #stack_init,sp
> move.l #stack_init,a7
> addql #1,dptr
> /* VBR */
> lea int_vec_tab,a0 | Get base of vector table
> movec a0,vbr | Set up the VBR
> addql #1,dptr
> /* pre MBAR work */
> movec dfc,d1 | Save destination register
> moveq #7,d0 | CPU-space funcction code
> movec d0,dfc | Set destination function code register
> movec d0,sfc | Set source function code register
> addql #1,dptr
> lea 0x3ff04,a0
> movel #0xfffffffe,0x3FF08 | Set MBARE (keyed write)
> move.l 0x3ff08,dptr+4
> addql #1,dptr
> /* get MBAR */
> moves.l (a0), d0
> move.l d0,dptr+8
> addql #1,dptr
> /* set MBAR */
> move.l #m360+0x101,d0
> move.l #0xffc00000,d0
> ori.l #0x00000101,d0
> moves.l d0,(a0) | set MBAR
> addql #1,dptr
> /* post MBAR work */
> movec d1,dfc | Restore destination register
> /* removed the rest here (e.g. interrupt table (copied from rtems))*/
> i havnt any further ideas what the problem could be.
> anyone any hint/info/... ?
> thx
> regards,
> seb
