Linker Script Initialized Data
Brett Swimley
brett.swimley at aedbozeman.com
Tue Jan 6 17:07:50 UTC 2004
Hi All-
My desire is to have a copy of initialized data that my BSP can copy to
the "working" data area at run time. I'm downloading via BDM to a
target system, and have to download the entire executible each time due
to not having variables re-initialized to default values. I'd like to
not have to dedicate a block of memory for this, but link the sections
contiguously, only allocating a separate section for the "src" of the
initialized data.
I'm trying to follow the concepts listed on the following page:
http://www.rtems.com/onlinedocs/doc-current/share/rtems/html/bsp_howto/bsp_howto00022.html
but I'm not convinced that things are working correctly.
FWIW, I load my .text section first, then .data, then .bss. All going
into the ram memory section (similar to the gen68340 linker script). Is
there a way to confirm that the objcopy command is doing what is
expected? Do I need to change my linker script to rearrange how sections
are loaded?
Can I accomplish the same thing just by making some changes in the
linkcmds file?
Any help or advice is appreciated.
Regards,
Brett
Brett Swimley
Advanced Electronic Designs
ph: 406-585-8892 fax: 406-585-8893
