mips exception handling - help needed
Mon Jan 12 14:14:03 UTC 2004
durai wrote:
> Hi,
> I am working in a mips processor which doesnt implement some instructions
> (lwl,lwr etc) and I wanted to emulate this instructions is exception
> handler.
> I am having a exception handler in linux with the following format.
> void do_ri( struct pt_regs *regs )
>  branchDelay = ( ( 0 != ( regs->cp0_cause & CAUSEF_BD ) ) ||   (
> isJumpInstruction( regs->cp0_epc ) ) );
>       Get the instruction that caused this
>       interrupt:
>     inst = *((unsigned long *)(regs->cp0_epc) + ( branchDelay ? 1 : 0 ));
> //emulate the instruction
I think you are trying to implement either an instruction not
implemented or an unaligned access exception handler.  You are
trying to emulate an instruction (or subset of an instruction)
that is not implemented in hardware.  Right?
> How can I  implement that handler in RTEMS? to be more precise, I wanted to
> know how to access the processor registers inside my exception handler, also
> i wanted to know whether  the processor registers will be saved before
> calling my exception handler. Will it be possible to to store the processor
> registers before calling the exception handler, because i have to get the
> instruction opcode from the stored registers and emulate it.
I am looking at c/src/lib/libcpu/mips/tx39/vectorisrs/vectorisrs.c which
is the routine responsible for vectoring exceptions.  It is passed an
interrupt stack frame (ISF) which is really the exception registers on
the stack.  See cpukit/score/mips/cpu_asm.S.  So it should be fairly
trivial to continue to pass the ISF down to an instruction emulator
routine which patches the stack frame.
I would read the code in cpu_asm.S very carefully to make sure you
interoperating with it correctly.
Greg Menke has done similar things to get some FPU exceptions handled
so might have some more insight.  But this is the general way to
handle it.
> regards
> durai
