Rtems with Philips LPC2106 ???
Jay Monkman
jtm-list-rtems at smoothsmoothie.com
Fri Jan 16 18:09:46 UTC 2004
On Fri, Jan 16, 2004 at 11:16:27AM -0600, Joel Sherrill wrote:
> That may be shrunk more with attention to the RTEMS
> configuration and what services you use. The ticker test
> has 3 tasks, uses printf (often 20-30K baggage itself),
> etc.. Did that size have itron and/or POSIX enabled?
Probably. It was with the default configuration:
configure --target=arm-rtems --enable-rtemsbsp=edb7312
Name: not available
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20040116/741522af/attachment.bin>
