Rtems with Philips LPC2106 ???
Joel Sherrill joel at OARcorp.com
Fri Jan 16 18:20:55 UTC 2004
Scott Newell wrote:
> At 11:16 AM 1/16/2004 , Joel Sherrill wrote:
>>That may be shrunk more with attention to the RTEMS
>>configuration and what services you use.  The ticker test
>>has 3 tasks, uses printf (often 20-30K baggage itself),
> Would using iprintf() help?
Yes.  And I think that in later RTEMS versions, the
tests actually (by macro magic) have switched to
using iprintf.
Better would be to avoid using printf unless you
really need it.  For debug IO to a serial console,
printk() is much smaller.
> newell
