termios with high baud rate...
Chris Johns cjohns at cybertec.com.au
Fri Jan 16 21:28:55 UTC 2004
Stan wrote:
> My application is a simple buffer.
> It must to work without hardware handshaking ( at least at 57600 ).
> The 5206e ColdFire is fast ( 50 Mhz ),  it should be fast enough
> for do it.
An RTEMS call exists in termios to change the default buffer sizes. I
have found this has helped in the past. The call is defined in
'rtems/libio.h' and is:
  rtems_status_code rtems_termios_bufsize (
    int cbufsize,     /* cooked buffer size */
    int raw_input,    /* raw input buffer size */
    int raw_output    /* raw output buffer size */
Note: The new buffer sizes only effects a tty opened after the call is
made. It does not try to change the size of open ttys.
  Chris Johns, cjohns at cybertec . com . au
