Problem with ATA driver on pc386
Eugene Denisov dea at sendmail.ru
Tue Jan 20 10:28:52 UTC 2004
It worked with 4.6.5pre4.
With pre4 I was able to build this but 'ata.h' is somewhere in other place
(I have not access to my RTEMS repository now so cannot say accurately where
it is)
----- Original Message -----
From: "Angelo Fraietta" <afraiett at bigpond.net.au>
To: "Eugene Denisov" <dea at sendmail.ru>
Cc: <rtems-users at rtems.com>
Sent: Tuesday, January 20, 2004 8:04 AM
Subject: Re: Problem with ATA driver on pc386
> Did you get this to work. I seem to having trouble getting it to work. I
> have tried pre4 with no success on my build. I get
> unable to open /rtems/ata.h
> error
> Eugene Denisov wrote:
> >Thank you, I'll try 4.6.0pre4.
> >I suspected the problem is in 4.6.0pre5, it seems this release is rather
> >raw, at least PCI support in i386 platform is broken and I had to modify
> >sources slightly.
> >Sent: Friday, December 12, 2003 1:18 AM
> >>Yes -- I am using rtems-4.6.0pre4 with pc386dx BSP
> >>This my systme header
> >>#include <bsp.h> /* for device driver prototypes */
> >>#ifdef RTEMS_BSP_HAS_IDE_DRIVER
> >>#include <rtems/ata.h> /* for ata driver prototype */
> >>#include <libchip/ide_ctrl.h> /* for general ide driver prototype */
> >>#endif
> >>#include <tty_drv.h>
> >>#include <console.h>
> >>#include <clockdrv.h>
> >>#include <timerdrv.h>
> >>#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> >>#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> >>#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
> >>#define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
> >>rtems_driver_address_table Device_drivers[] = {
> >>        CONSOLE_DRIVER_TABLE_ENTRY,
> >>        TTY1_DRIVER_TABLE_ENTRY,
> >>        /*TTY2_DRIVER_TABLE_ENTRY,*/
> >>                MIDIPORT_1_DRIVER_TABLE_ENTRY,
> >>        CLOCK_DRIVER_TABLE_ENTRY,
> >>                IDE_CONTROLLER_DRIVER_TABLE_ENTRY,
> >>                /* important: ATA driver must be after ide drivers */
> >>                ATA_DRIVER_TABLE_ENTRY ,
> >>#endif
> >>        {NULL,NULL,NULL,NULL,NULL,NULL},
> >>#include <rtems/bdbuf.h>
> >>rtems_bdbuf_config rtems_bdbuf_configuration[] = {
> >>  {512,128,NULL}
> >>int rtems_bdbuf_configuration_size =( sizeof(rtems_bdbuf_configuration)
> >>                     /sizeof(rtems_bdbuf_configuration[0]));
> >>#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 50
> >>#define CONFIGURE_MICROSECONDS_PER_TICK 1000 /* 1 ms */
> >>#define CONFIGURE_MAXIMUM_TASKS             20
> >>#define CONFIGURE_MAXIMUM_SEMAPHORES 20
> >>#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES    20
> >>#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> >>#define CONFIGURE_EXTRA_TASK_STACKS
> >>(CONFIGURE_MAXIMUM_TASKS*10*RTEMS_MINIMUM_STACK_SIZE)
> >>>Hello all.
> >>>I trying to use ATA driver in RTEMS 4.6.0pre5 on pc386 target, this is
> >the
> >>>driver table I used to:
> >>>#ifdef CONFIGURE_INIT
> >>>       ,CLOCK_DRIVER_TABLE_ENTRY
> >>>       ,IDE_CONTROLLER_DRIVER_TABLE_ENTRY
> >>>#if 1
> >>>       ,ATA_DRIVER_TABLE_ENTRY
> >>>#endif
> >>>Unfortunately system hungs up when I enabling ATA driver.
> >>>Does anyone succesfully use ATA driver for this RTEMS build?
> >>Angelo Fraietta
> >>PO Box 859
> >>Hamilton NSW 2303
> >>Home Page
> >>http://www.users.bigpond.com/angelo_f/
> >>There are those who seek knowledge for the sake of knowledge - that is
> >CURIOSITY
> >>There are those who seek knowledge to be known by others - that is
VANITY
> >>There are those who seek knowledge in order to serve - that is LOVE
> >>    Bernard of Clairvaux (1090 - 1153)
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
CURIOSITY
> There are those who seek knowledge to be known by others - that is VANITY
