Problem with ATA driver on pc386
Angelo Fraietta afraiett at bigpond.net.au
Tue Jan 20 21:44:09 UTC 2004
Eugene Denisov wrote:
>Thank you, I'll try 4.6.0pre4.
>I suspected the problem is in 4.6.0pre5, it seems this release is rather
>raw, at least PCI support in i386 platform is broken and I had to modify
>sources slightly.
I just tested with pre 5 and it worked fine.
After installing, eg, where /opt/rtems is the install point
make RTEMS_BSP=pc386dx install
Is it possible anywhere within /opt/rtems to see the actual version of
RTEMS I have installed?
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
