Fw: RTEMS - Image Loading problem for MIPS thru MAJIC
Ed Sutter
els at emailbox.hdtv.lucent.com
Mon Jan 5 15:40:56 UTC 2004
Mansoor/Joel,
Is this symbol table information? If yes, then maybe the file
should be stripped prior to transferring it to the target.
There shouldn't be any need to have all the symbol table sections
on the target, correct?
Ed Sutter
Joel Sherrill wrote:
> mansoor wrote:
> > HI
> > I built the RTEMS hello.exe using the mips-rtems toolchain. Iam using
> > rtems-4.6.0pre5 source configured
> > for our board (MIPS lx4189 r3000 based core).
> > Iam using EPI MAJIC to load the image the to the target.
> > When I tried downloading the hello.exe image to the target, MAJIC
> > continuosly throws
> > the following errors.
> > ERROR, input record not processed:
> > STAB 21 LSYM 00000000 0 "complex float:t18=R3;8;0;"
> > STAB 22 LSYM 00000000 0 "complex double:t19=R4;16;0;"
> > STAB 23 LSYM 00000000 0 "complex long double:t20=R4;16;0;"
> > I started my porting work with the jmr3904 BSP as base and iam using the
> > same rules for my target.
> > Also, for the same board we have ported linux using mips-linux toolchain
> > (gcc 2.95.3 as base).
> This looks like the bootloader does not understand some information
> in the image. Are they using the same binutils versions? It sounds
> like the RTEMS binutils has more information than the ROM monitor
> understands and you might have to use objcopy to deal with it.
> > Iam successfull in loading linux image thru EPI MAJIC.
> > What could be the problem ???.
> >> Thanx in advance
> >> Mansoor Ahamed Basheer
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
