unable to disassemble to source
Scott Newell
newell at cei.net
Wed Jan 7 16:57:37 UTC 2004
>> Iam working on porting RTEMS 4.6.0 pre5 to MIPS lx4189 (r3000 mips1) core
>> based board. I am using the latest mips toolchain from the rtems website.
>> When I try to disassmble the hello.exe with "mips-rtems-objdump -S
>> hello.exe" , I am getting only the assembly code and no c source code.
>> when i try to disassemble the indiviual object files , I am able to find
the
>> c source with assembly code.
>> How can I get the disassembled code with c source?
>You can't. It's impossible.
Hmmm. Maybe impossible from the s-record format image file, but not from
an elf format file? Or impossible from an .o object file?
m68k-rtems-objdump -S -d ticker.nxe:
[snip]
00100a64 <bsp_start>:
* bsp_start
* This routine does the bulk of the system initialization.
void bsp_start( void )
void *vbr;
extern void *_WorkspaceBase;
extern void *_RamSize;
extern unsigned long _M68k_Ramsize;
_M68k_Ramsize = (unsigned long)&_RamSize; /* RAM size set in linker
script */
100a64: 23fc 0008 0000 movel #524288,113ab8 <_M68k_Ramsize>
100a6a: 0011 3ab8
* we only use a hook to get the C library initialized.
Cpu_table.pretasking_hook = bsp_pretasking_hook;
100a6e: 23fc 0010 1044 movel #1052740,11383c <Cpu_table>
100a74: 0011 383c
Cpu_table.predriver_hook = bsp_predriver_hook;
100a78: 23fc 0010 0a5c movel #1051228,113840 <Cpu_table+0x4>
100a7e: 0011 3840
Cpu_table.postdriver_hook = bsp_postdriver_hook;
100a82: 23fc 0010 1560 movel #1054048,113844 <Cpu_table+0x8>
100a88: 0011 3844
m68k_get_vbr( vbr );
100a8c: 4e7a 1801 movec %vbr,%d1
Cpu_table.interrupt_vector_table = vbr;
100a90: 23c1 0011 3864 movel %d1,113864 <Cpu_table+0x28>
BSP_Configuration.work_space_start = (void *) &_WorkspaceBase;
100a96: 23fc 0011 5440 movel #1135680,113868 <BSP_Configuration>
100a9c: 0011 3868
[snip]
newell
