unable to disassemble to source
durai
durai at isofttech.com
Thu Jan 8 05:49:18 UTC 2004
Hi ralf,
Could you please tell me the reason why it cant be done?
This is built with -g option enabled.
also when I tried
"mips-rtems-objdump -S -g hello.exe" it throws an error
mips-rtems-objdump: hello.exe.img: no recognized debugging information
regards
durai
----- Original Message -----
From: "Ralf Corsepius" <corsepiu at faw.uni-ulm.de>
To: "durai" <durai at isofttech.com>
Cc: "RTEMS Users" <rtems-users at rtems.com>
Sent: Wednesday, January 07, 2004 9:20 PM
Subject: Re: unable to disassemble to source
> On Wed, 2004-01-07 at 15:56, durai wrote:
> > Hi,
> > Iam working on porting RTEMS 4.6.0 pre5 to MIPS lx4189 (r3000 mips1)
core
> > based board. I am using the latest mips toolchain from the rtems
website.
> > When I try to disassmble the hello.exe with "mips-rtems-objdump -S
> > hello.exe" , I am getting only the assembly code and no c source code.
> > when i try to disassemble the indiviual object files , I am able to find
the
> > c source with assembly code.
> > How can I get the disassembled code with c source?
> You can't. It's impossible.
> Ralf
