Problems linking to calloc
Mark Mussetter
mark at link-comm.com
Thu Jan 8 21:22:31 UTC 2004
Thank you for responding so quickly!
That seemed to do the trick for this round of errors. There was a problem
in my Arch.rules file. I had commented out the CFLAGS += ..... line and
tried to duplicate it with my own requirements. I must've had a tab
instead of spaces (or vice versa). I uncommented the old CFLAGS +=
...... line and changed it to meet my requirements and it worked.
Thanks again,
Mark
At 02:49 PM 1/8/2004 -0600, you wrote:
>Mark Mussetter wrote:
>>Hi everyone,
>>I am running rtems-4.6.0pre5 on a motorola 5272. I am also going to run
>>Microwindows on top of rtems. I can get a clean build of Microwindows
>>for rtems, but if I try to build any demos, I get errors from the linker
>>saying that it can't find calloc, rtems_semaphore_obtain, and others.
>>We do have the code for these functions in the rtems tree, but they
>>aren't getting linked in for some reason.
>>Is there a library that needs to be linked in that we are missing?
>I don't see the "-B... -qrtems" part of the FCC arguments on this
>so you are not linking against RTEMS.
>>Below is a clip from the build log:
>><SNIP>
>>/opt/rtems-4.6/bin/m68k-rtems-gcc -I.
>>-I/microwindows/microwindows-0.90-rtems/src/include -I/usr/include/freetype2
>>-L/microwindows/microwindows-0.90-rtems/src/lib nxscribble.o
>>scribwidget.o hre_api.o li_recognizer.o bitvector.o matrix.o sc.o util.o
>>-o /microwindows/microwindows-0.90-rtems/src/bin/nxscribble
>>/microwindows/microwindows-0.90-rtems/src/lib/libnano-X.a
>>/microwindows/microwindows-0.90-rtems/src/lib/libmwengine.a
>>/microwindows/microwindows-0.90-rtems/src/lib/libmwdrivers.a
>>/microwindows/microwindows-0.90-rtems/src/lib/libmwfonts.a
>>/usr/lib/libfreetype.a -lm
>>/opt/rtems-4.6/lib/gcc-lib/m68k-rtems/3.2.3/../../../../m68k-rtems/bin/ld:
>>warning: cannot find entry symbol _start; defaulting to 80000074
>>/microwindows/microwindows-0.90-rtems/src/lib/libnano-X.a(nxutil.o): In
>>function `GrNewBitmapFromPixmap':
>>nxutil.o(.text+0x516): undefined reference to `calloc'
>>/microwindows/microwindows-0.90-rtems/src/lib/libnano-X.a(srvmain.o): In
>>function `GsAcceptClientFd':
>>srvmain.o(.text+0x22): undefined reference to `close'
>>function `GrOpen':
>>srvmain.o(.text+0xc6): undefined reference to `rtems_semaphore_obtain'
>>srvmain.o(.text+0xf0): undefined reference to `rtems_semaphore_release'
>>srvmain.o(.text+0x11c): undefined reference to `rtems_semaphore_release'
>>and on and on and on......
>><END SNIP>
>>Thanks for any help you might provide,
>>Mark
>Joel Sherrill, Ph.D. Director of Research & Development
>joel at OARcorp.com On-Line Applications Research
>Ask me about RTEMS: a free RTOS Huntsville AL 35805
>Support Available (256) 722-9985
