termios with high baud rate...
Brett Swimley brett.swimley at aedbozeman.com
Fri Jan 16 15:38:40 UTC 2004
I had an error with my reply as well (similar to Charles).
Note Charles' response is similar to mine.
Brett
Brett Swimley wrote:
> Are you sure that you're not running into a receive buffer overrun?
> I was working with some early versions of termios about a year ago
> with the 5272, and decided to abandon it for more streamlined serial
> port interrupt drivers because the overhead of the termios hooks
> _appeared_ to cause me to not be able to read subsequent characters
> from the Rx FIFO fast enough.  IIRC, the  5206e only has up to a 4
> byte Rx FIFO.
> Worth looking into??
> Brett Swimley
> Stan wrote:
>>----- Original Message -----
>>From: "Charles Steaderman" <charlies at poliac.com>
>>To: "Stan" <zylog at club-internet.fr>
>>Cc: "rtems-users" <rtems-users at rtems.com>
>>Sent: Thursday, January 15, 2004 9:30 PM
>>Subject: Re: termios with high baud rate...
>>>I have a custom 5206e board working with 60096 baud with interrupt based
>>>termios, although the data from the sending device is not entirely
>>>continuous. I will see if I can find a way to quickly modify my
>>>application to test at 115200. How are you sending a continuous stream?
>>I send a text file with one terminal (PC).
>>>I am sure that hardware handshaking will be necessary. Is that OK for
>>>your application?
>>>- Charlie
>>My application is a simple buffer.
>>It must to work without hardware handshaking ( at least at 57600 ).
>>The 5206e ColdFire is fast ( 50 Mhz ),  it should be fast enough
>>for do it.
>>Stan.
>Brett Swimley
>Advanced Electronic Designs
>ph: 406-585-8892 fax: 406-585-8893
Brett Swimley
