Problem with ATA driver on pc386
Ralf Corsepius corsepiu at faw.uni-ulm.de
Tue Jan 20 12:58:25 UTC 2004
On Tue, 2004-01-20 at 13:46, Eric Valette wrote:
> Ralf Corsepius wrote:
> > On Tue, 2004-01-20 at 11:28, Eugene Denisov wrote:
> >>It worked with 4.6.5pre4.
> >>With pre4 I was able to build this but 'ata.h' is somewhere in other place
> > Joel has moved it to libchip/ide, so it now can be found inside of the
> > source tree at: c/src/libchip/ide/ata.h
> > After installation it is supposed to be located at
> > $(includedir)/libchip/ata.h
> > => You want to
> > #include <libchip/ata.h>
> Considering the importance of disk storage in many new embedded system
> (mp3 player, ...), I think that sooner or later it will be as mandatory
> as TCP/IP in the past. So even if it is not perfect, having a test that
> builds ATA + FAT32 + create some files in an example application would
> be a good idea and would avoid this kind of problem...
Contributions are welcome! ;)
Ralf
