Problem with ATA driver on pc386
Eugene Denisov
dea at sendmail.ru
Wed Jan 21 09:49:33 UTC 2004
----- Original Message -----
From: "Angelo Fraietta" <afraiett at bigpond.net.au>
To: "Eugene Denisov" <dea at sendmail.ru>
Cc: <rtems-users at rtems.com>
Sent: Wednesday, January 21, 2004 12:44 AM
Subject: Re: Problem with ATA driver on pc386
> Eugene Denisov wrote:
> >Thank you, I'll try 4.6.0pre4.
> >I suspected the problem is in 4.6.0pre5, it seems this release is rather
> >raw, at least PCI support in i386 platform is broken and I had to modify
> >sources slightly.
> I just tested with pre 5 and it worked fine.
> After installing, eg, where /opt/rtems is the install point
> make RTEMS_BSP=pc386dx install
yes, I also get some results with pre5, the problem I found was in dosfs
driver - it incorrectly work with disks containing ext2 and NTFS partitions
and, it seems, with non dos MBR.
> Is it possible anywhere within /opt/rtems to see the actual version of
> RTEMS I have installed?
I think not
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> http://www.users.bigpond.com/angelo_f/
> There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
> There are those who seek knowledge to be known by others - that is VANITY
> There are those who seek knowledge in order to serve - that is LOVE
> Bernard of Clairvaux (1090 - 1153)
